where to get transgo shift kit for my GTA?
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
ok, i've read the mile long threads about how the B&M shift kits suck for 700-R4s, so now my question is where did you guys get your kits? JEGS doesn't have transgo, only B&M so that's not an option.
Car: check
Engine: check
Transmission: check
Re: where to get transgo shift kit for my GTA?
RBob.
Car: 99 Formula
Axle/Gears: 342
I think it's www.probuiltautomatics.com
sorry mark, RBob go it right. anyways, there are two types: the heavy duty kit and the street/strip kit with 1/2 accumulator. Which on is better?
Car: check
Engine: check
Transmission: check
What I received had a mix from two TransGo kits along with some extra stuff like the larger servo & boost valves, and the 1/2 accumulator setup. Directions were included. The results . . . well, I should have done it the day I purchased the car.
RBob.
amazing, another first-day mod just like sfc's?
dhonda200
Aug 11, 2015 11:50 PM
