T56 pedals vs/ T5 pedals
Old Jun 15, 2003 | 08:28 AM
BOTTLEDZ28's Avatar
Transmission: A4
I have a t56 in my car and Im using my T5 pedals but I read somewhere that the clutch setup on the T56 is not designed for the pedal travel on the t5 pedal. Is this true? Do the both pedal shave a different travel length?
Old Jun 15, 2003 | 10:52 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I have had both. I originally installed the 4th gen pedal beacause they just look designed better than the 3rd gen pedals. After the necessary mods to make them fit they worked fine until I noticed thet my brake pedal was too low in comparison to my gas pedal; they were almost at the same height. So I threw in the 3rd gen pedals and it gave me about 1/2" more in pedal height. Both pedals function fine although with the 4th gen pedals I did have to make a stop for the clutch pedal otherwise the clutch fork would banf against the PP but I know of people who have had the same contact problem with 3rd gen pedal as well (may be related to Mcleod clutch) I did have the take the T56 clutch MC arm bushing and drill it out and modify it to get the rod to fit the 3rd gen pedals and still have a bushing.
summary: The clutch pedal travel isn't an issue but the brake pedal height difference is an issue.
Old Jun 16, 2003 | 04:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
thanks for the reply and info. I had the same problem with a meloed clutch. I ended up pulling it out and putting an SLP clutch in instead since the PP was ruining from the fork. It locked up on me on the highway.
grngryoutmyway
Oct 18, 2016 05:48 PM
camaro1185
Oct 26, 2015 06:51 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
