Rear end swap?
Old Jun 16, 2003 | 10:49 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
Rear end swap?
Ok been doing some research on rear ends. I am unfornatly stuck with a9 bolt Borg warner rear end in my Iroc - Z with ***** 2.77's There is no aftermarket for this rear end! And the little that there is is expensive. So I wanted to know if a 4th gen like 95 or 96 rear end will swap in. I wanted to get the posi rear with 323 facotry. They are 10 bolts in the 4th gens right?
Input please!
Justin
Old Jun 17, 2003 | 01:16 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't help ya with the 4th Gen, but there is a member who sells BW 9-bolt gears, carriers, etc.
Think his name is miles427...something like that.
Search on the Drivetrain forum for him.
Old Jun 17, 2003 | 02:49 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
looked at the tech articles on the main page lately?
Old Jun 17, 2003 | 05:06 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I too was once cursed with a BW 9 bolt with 2.77's, although it wasn't really a curse to have the rearend, just that ratio of gears. I swapped it out for a Moser 9" with 3.70's that I eventually sold because I hated it and bought a 96 model rear from a Camaro Z28 for $250. The 96 rear also cursed me with 2.73 gears which I just replaced this past weekend with 4.10's. But the good thing about it is that it bolted up perfectly with absolutely no modifications whatsoever other than changing a brake line(the one that runs from the rear to the body). The e-brake cables even worked perfect(though I had disk brakes on the 9 bolt.). If i'm not mistaken if you already have disk brakes and get a rear from a 93-96 4th gen the e-brake cables will work...Someone correct me if i'm wrong.
Old Jun 17, 2003 | 09:51 PM
I RoC A Z's Avatar
Thanks for the info guys. Be easy on me I am NEW!
Justin
any other input welcome
Old Jun 20, 2003 | 01:37 AM
750gixxer's Avatar
4th gen rear ends are 2 inches wider on both sides
Old Jun 20, 2003 | 03:01 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You're wrong, but I wish you were right.
My 86 9bolt disc e-brake cables are different. Didn't hook up to the 95 brakes.
Old Jun 20, 2003 | 03:56 AM
85TPI400's Avatar
Zepher,
Didnt the 89 use the PBR brakes vs the 86 having the non PBRs?
Old Jun 20, 2003 | 04:02 AM
Zepher's Avatar
Originally posted by 85TPI400
Zepher,
Yep, that is the difference I believe.
88 and earlier disc Calipers sat on opposite sides of the wheel and the 89+ had them sitting on the back side of the wheel, I believe.
Old Jun 20, 2003 | 05:16 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Re: Rear end swap?
Justin
Stuck with a 9 bolt. You could be happier then a pig in mud to have a 9 bolt. The 2.77's are somewhat of a curse but the 9 bolt, yet hard to find is a hell of alot stronger then a 10 bolt. 9bolt.com will have everything you need. Will probably cost around $800 to swap in the 3 series carrier but will be worth it in the long run. This is what I have to do, not really happy to have the 2.77's but if life gives you a 9 bolt, build her up.
Car: 1988 GTA
Transmission: TH350
Re: Rear end swap?
Justin
Old Jun 21, 2003 | 12:37 AM
I RoC A Z's Avatar
Hey thanks for the info yeah about 800 bucks is a lot cheaper then what I was hear to keep the rear end!
Old Jun 23, 2003 | 11:32 PM
R.O.B.'s Avatar
Although the 9-bolt is stronger, unless your running hella-horsepower, the 10-bolt will be just fine. I just finished swaping in an 88 rear with 3.42 gears. All factory setup, just bolted in, changed the vehicle speed sensor, and had fun.
Old Jun 24, 2003 | 01:07 PM
tpi_roc's Avatar
What didn't you like aboutr the moser 9"?
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
