a rearend question...
Old Jun 23, 2003 | 08:23 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
does anyone have or had at one time, a strange engineering 12 bolt?? if so what are your experiences with it, good or bad?? also, has anyone beefed up the stock rearend? if so, how, and what were the best years to beef up, or are they all the same. thanks.
Old Jun 23, 2003 | 09:03 AM
ede's Avatar
ede
for any rear with a cover use a girddle or braced cover, weld the tubes to the center section, c clip eliminators to increase strength
Old Jun 23, 2003 | 09:15 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
what exactly would welding the tubes together do, i have no idea about rearends... also, is that something for a street driven car? or just something for someone who wants to race.
i am gonna have to strengthen my rearend when i do my engine swap so i wanted to know if the stock rearend could be safely made capable, or if its best to get a new one? thanks
Old Jun 23, 2003 | 11:17 AM
ede's Avatar
ede
eliminates flex, which is what kills most rears
Old Jun 23, 2003 | 11:23 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
this may sound like a stupid question, but... welding the tubes together wont affect a posi unit will it?? it would be suitable for daily driving??
Old Jun 23, 2003 | 11:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Welding the tubes refers to the axle tubes where they attach to the center sction of the housing. The factory uses 2 spot welds. To strengthen it, you weld all the way around the tube where it plugs into the center. It has nothing to do with the posi feature if it exists, and has no impact on using it as a saily driver. My DD has its tubes welded.
That, a stud girdle cover, a solid pinion bearing spacer, a good posi, some better axles (Superior or other stock-configuration ones are better in this application than "custom" ones such as Moser), and a good posi carrier, are about all you can do to beef it up. Synthetic fluid of course.
Old Jun 23, 2003 | 11:59 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
ok...so what im trying to get at is, will a stock 82 rearend, "beefed" up, with what you guys suggested hold up to a stock LS1, i plan on swapping an LS1 but i dont want to mod the engine right away, not until i fully address the suspension and rearend. will i be alright?
Old Jun 23, 2003 | 12:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well considering that except for the axle splines the 82 rear is already the same as a stock LS1 rear, it should do fine as long as the driver doesn't beat on it too much.
Old Jun 23, 2003 | 08:47 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
thats what i needed to know, thank you... but that brings another question to mind. why do people swap in 4th gen rears??
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
happyhapka
Aug 15, 2015 04:42 PM
