9 bolt w/4.10 whines
Old Jun 24, 2003 | 10:25 AM
Ringmaster72's Avatar
Car: 1989 IROC
I just had 4.10 gears put in my 9 bolt last week and it whines pretty good going down the road. I was just curious if this was normal with the higher ratios in the 9 bolt, anybody have one with high gears?
Tim
Old Jun 24, 2003 | 10:56 AM
SLP_GTA's Avatar
is it whining under load or coast or
both.
I have one that only whines under coast, its not bad but I am picky
Old Jun 24, 2003 | 11:48 AM
Car: 1989 IROC
It whines mostly when I am just driving along. Not when I am accelerating, just when it evens out and is at a steady cruising rpm.
thanks
tim
Old Jun 24, 2003 | 02:55 PM
Steve89GTA's Avatar
Are you sure it's the rear?
I chased this problem for months and it turned out to be the inner bushing in the tranny where the driveshaft yoke goes in.
Old Jun 24, 2003 | 04:07 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Aside from the whine, how do you like the 4.10 gears with your combo of stealth ram and t56? Are you glad you went with 4.10's or do you wish you'd gone with 3.90's or 3.70's now?
Old Jun 24, 2003 | 10:54 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What speed is the whine at?
Old Jun 24, 2003 | 11:32 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
mine do the same exact thing. Who put yours in? i talked to tony about it and he said he would buy me another set and do them free, but i don't think he realises the gear sets are as much as they are..
Eric
Old Jun 25, 2003 | 01:02 AM
beamar's Avatar
where do you get 4.10 gears for a 9 bolt??? Only gears I've ever seen for the 9 bolt is from strange and they are 3.70's...
Old Jun 25, 2003 | 06:20 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
www.diffsolutions.com
Old Jun 25, 2003 | 08:06 AM
Car: 1989 IROC
It whines at pretty much any speed above 30mph when cruising. It does not whine much when accelerating or slowing down. It is pretty loud. Zupman, does this sound familiar to you, it almost sounds like a bearing to me. I am not sure I want to hear this forever Drain,yeah so far I am happy with the 4.10s,if they were not so noisiy.
Tim
Old Jun 25, 2003 | 06:10 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
that sounds exactly like my problem. They don't whine under 20 mph, they don't whine under heavy acceleration, and they don't whine on decelleration. But they whine like crazy at cruise and when lightly accelerating. Wonder if this i a ring and pinion problem....who put yours in?
Eric
Old Jun 27, 2003 | 10:06 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
hey ringmaster, how did you go from a 2.77 to a 4.10? i have a 2.77 nine bolt in my formula and i was told that i needed a 3 series carrier. i am completely retarded when it comes to rear ends, but i would like to upgrade to a 3.73 and i was just wondering what all it takes. thanks man!!!
Old Jun 30, 2003 | 01:28 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
bubbz89,
The low series carrier, which is for 2.77 gears is different form the high series carrier 3.23+. In order to install 3.73 gears in your rear end you need to change out to the high series carier no way around it(10 bolt people can use a spacer).
That link that Zupmanz28 posted has the carriers for sale. Also check the classifieds on this site as there is someone who is currently selling a 3 series carrier and 3.45 grears for around $250. If I had the money at the moment I would buy it as it is a good deal and I'm also currently stuck with 2.77
Old Jun 30, 2003 | 04:30 PM
bubbz89's Avatar
Car: 1990 RS
thanks man
Old Jul 3, 2003 | 11:47 AM
Ezey Go's Avatar
What name brand did you go with? If it is Richmond gears then the whine is normal. After the gears get broken in the whine will go away.
Old Jul 3, 2003 | 12:31 PM
Hey bubbz89, I just picked up a 3 series carrier and 3.23 gear set on ebay for $110. Check it out as there are a few 9bolt parts on ebay right now. I won't have to deal with break in whine since these are broken in already
Old Jul 12, 2003 | 01:15 PM
Car: 1989 IROC
Eric, I just finally got my car back after having the guy go back in there. The whine is gone now, it is nice and quiet. The problem was that the pinion was not deep enough into the ring gear. It is nice now.
Tim
Old Jul 12, 2003 | 05:29 PM
bubbz89's Avatar
Car: 1990 RS
so i just need the posi unit with the gears? if so, around how much does it cost to install? thanks man
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
