t56 rebuild kit
Old Jul 1, 2003 | 04:01 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
t56 rebuild kit
Where is a good place to find one at?
Chris
Old Jul 1, 2003 | 04:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Are you just refreshing synchro linings? Lemme know what you need, I can get it.
Old Jul 1, 2003 | 06:15 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Well it is out of a friends car, that I am putting into mine. It is popping out of 5th and grinding in reverse. Other than that it is OK, I hope
chris
Old Jul 1, 2003 | 06:35 PM
jmd's Avatar
jmd
Right on. I'll work on the refresh kit pricing tomorrow, and then when you get it apart, we'll talk 5th gear parts if necessary.
-Matthew
Old Jul 2, 2003 | 09:04 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
-Matthew
Awesome!:hail:
Chris
Old Jul 2, 2003 | 11:44 AM
black84-6spdz28's Avatar
look up a place called "d&d performance"....its got the synchros, bearings and steel 3-4 fork...not bad prices either
Old Jul 2, 2003 | 12:14 PM
jmd's Avatar
jmd
Nuff, will update later today.
Old Jul 7, 2003 | 09:26 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Any updates?
chris
Old Jul 8, 2003 | 09:31 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Just an FYI....
That D&D Performance place wants:
$229 for synchros
$199 for bearings
$49 for the steel 3-4 shift fork (stock one is cast AL and is poopey).
Doesn't sound too bad but then again I haven't priced anything out for this stuff.... like at all!
Old Jul 15, 2003 | 08:16 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The "popping out of 5th" issue is most likely a bent shift fork. The 5th-6th fork is not as strong as the 1st-2nd and 3rd-4th forks (they are overdrive gears after all,) so if someone liked to powershift into 5th they could VERY easily have bent the fork.
When I bought my T-56 it had no 4th gear and popped out of 3rd. I paid $16 for a 3-4 shift fork, and a few bucks for a full set of shift fork pads, and voila!! It shifts perfectly into every gear. Definitely get the steel forks, they're well worth the money (wish I had know about them when I tore mine down.....)
Reverse is a synchro issue. The reverse synchro is brass, the others are all composite. It doesn't like being shifted into reverse while moving forward.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
