clutch replaced, new prolem...
Old Jul 6, 2003 | 01:13 PM
edin's Avatar
clutch replaced, new problem...
1991 camaro/305v8: ok, i was driving from pensacola fl to charleston sc and on the way my clutch took a ****. i replaced all the hydrolic clutch parts and that turned out not to be the problem, the cluth actually broke where one of the 5 springs is held in, so i replaced all the clutch parts, everything except for the pilot bearing (the car was in a gas station parking lot in the middle of nowhere, so tools and what not were limited and i had no way to get the old bearing out)... the bearing was worn but i had no other choice. so i put the car back together and it now shifts very very smooth EXCEPT for 3rd gear.... every time i shift into 3rd it sounds like it grinds for a second before going into gear... it's no harder to put into gear, but the sound worries me.... my tranny taking a **** now too?? thanks!
Old Jul 6, 2003 | 11:19 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Sounds like what my T-5 did when it was cold tell it finally blew. You might want to look into getting a rebuild if you plan on staying with you T-5.
Old Jul 7, 2003 | 06:13 PM
edin's Avatar
arg! lol, how much is a rebuild kit? or would it be cheaper/easier pulling a decent used tranny from the junk yard?
Old Jul 11, 2003 | 07:15 PM
edin's Avatar
ok, more info on the problem.... it makes the weird grating sound for only a second when going into 3rd gear from any other gear, ie 2nd gear, neutral, then into 3rd... but if i go out of 3rd to neutral, then back into 3rd, it won't make the noise. also, with the car shut down and not moving, i can shift into 3rd gear no problem, no noise, smooth as silk. i heard maybe i need to flush my tranny fluid, could this be the issue?? also, if i do need to rebuild my tranny, i could just replace 3rd gear and it wouldn't be too difficult? thanks a ton!
Old Jul 12, 2003 | 09:33 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Synchro... the rebuild kit doesnt cost much. I think I paid around 170-200.
Old Jul 13, 2003 | 02:19 PM
edin's Avatar
ok, synchro.... yer the second person to tell me that so i'll buy a tranny rebuild kit aug 1st (pay day) lol, thanks.
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
