visual t5 inspection?
Old Jul 7, 2003 | 11:39 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
I'm getting a used t5 from an 86 2.8L firebird soon to swap into my car thats got an automatic right now. is there anything i could check visually on the tranny that would indicate a problem? i'll have a 30 day warrenty on it but is there anything to check/look at before i install it? pull the pan off and look for gear bits?
Old Jul 8, 2003 | 09:10 AM
Odyssey's Avatar
There is no "pan" to pull off. I would check the input shaft and make sure there isn't overly excessive play in it. Also try to spin it and listen for unusual noises. Go through all the gears on it also. That's really about it... unless you open it there's not much else you can check from the outside.
Old Jul 8, 2003 | 10:44 AM
TekViper's Avatar
Engine: 3.1L v6
is it a lot of work to open the case up and look for damage?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sylentnite
Sep 9, 2015 02:55 PM
r90camarors
Dec 15, 2002 11:02 PM
tpi4me
Oct 17, 2001 02:56 PM
GTARob
Oct 2, 2000 12:43 PM
