9 bolt woes
Old Jul 10, 2003 | 11:13 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
9 bolt woes
I have a 9 bolt rear with what I think is a bad wheel bearing. The whining increases with speed and goes away when I make a lane change to the right. But right now that isn't my main concern with the mess. My rotors are rusted to the axles! I've tried all different types of rust penetrant and even a mid sized hammer will take chunks out of the rotor. Not to mention flatenig some threads on the studs. These things are NOT moving.
So I guess my question is something like... is there any other way of getting the axles out of the housing? I don't really want to drill through the rotors to try and reach the bearing retainer bolts. Are those 'T' bolts easy to find and replace?
In the mean time I am looking for someone who has an oxy fuel torch to heat up the rotors.
Old Jul 10, 2003 | 11:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well i have never been in a 9bolt, i assume it has c-clip axels, if so, take off the back cover, rotate the carrier until you can see screw that realeases the retaining pin, remove the screw, the slip big retaining pin (goes right now the center of the carrier) when that is out, you can push the axle IN, it will move 1/4" or so, once it is pushed in, pull the C-clip off the axel, then the whole axel will slide out.
hope that helps.
Old Jul 10, 2003 | 11:20 AM
slowTA's Avatar
Car: '88 Formula
Nope.. no c-clips. It comes with non c-clips axles and the axle bearing hold them in on their own. There are 4 bolts at the end of the housing that hold in the bearing retainer and brake backing plate. Those have to come out to get the axles out, with the help of a slide hammer.
Old Jul 10, 2003 | 11:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
well in that case i am not going to be much help
Old Jul 10, 2003 | 08:30 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yep I had to heat up mine. I did not care about the rotors because I was putting my larger ones on it so I fuged up the rotors real good and they did not budge till the hot wrench hit them.
Old Jul 10, 2003 | 09:18 PM
slowTA's Avatar
Car: '88 Formula
So... are we talking red hot or something a little less intimidating? The rotors are still in great shape (probably because the calipers don't work too well) so I would like to salvage them if possible. That wasn't a propane torch was it?
How is this one for a long shot of a question... you wouldn't happen to remember the size of the nuts on the bearing retainers, do you?
Old Jul 13, 2003 | 09:14 PM
slowTA's Avatar
Car: '88 Formula
For those searching, it is a tank of MAPP gas. Make sure your nozzle works with it since not all the propane ones work for both gasses. It took about half an hour of heating per rotor plus some beating with the hammer.
Old Jul 14, 2003 | 02:53 AM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Borrow or rent a real torch with Oxygen/Acetyline gas. It would make it much easier... Careful though things heat up quick!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
