Grinding noise from torque converter or tranny?
Old 07-16-2003, 11:48 AM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
I hear an ugly grinding noise coming from my torque converter. I don't think its coming from inside the tranny but I guess it's possible. It sounds like bearings have broken and they are grinding around inside. I know it's not the engine because I unbolted it from the torque converter, started it and the noise went away. Have any of you encountered a problem like this before and what could it be? I am planning on just buying a torque converter and swapping it out. The tranny still shifts fine. Do you recommend rebuilding the tranny too.
I've got an 89 IROC 5.7L 700R-4. How many splines do I need the torque converter to mate with?
Old 07-16-2003, 12:38 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
More likely to be the front pump. But it could be the converter. Or both.
Old 07-16-2003, 02:09 PM
kewl_blades's Avatar
Car: 2x1991 & 2000 Camaros
Engine: 350, 305 & LS1
Transmission: TH-700R4 and 4l60E
Torque converter rattle.
Old 07-17-2003, 12:36 AM
bigdaddyvu's Avatar
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
mount
There is one problem that is always over looked and its a common problem The tranny mount seperate (due too hard launches) and causes a rubbing grinding sound. But this only occurs when vehicle is in gear and/or in motion.
Old 07-17-2003, 10:15 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it most possibly can be the tc. probably some to due with the stator (tc). it could also be the pump as 5-7 metioned. regardless take the tranny down and inspect the tc, input shaft, pump, and pump bushing. 89' 700r4' has a 30 spline count. there a few places in town that have stock tc's for about $60. best of luck.
TWON_3rdGEN (08-06-2019)
Old 09-27-2010, 08:51 PM
hungry4des's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Re: Grinding noise from torque converter or tranny?
Took my tranny to get rebuilt. It was planetary gears. They looked all chewed up. Turns out that is the reason I had a very slight vibration in 3rd gear under very hard acceleration for many years. Thanks for the help guys.
xxx3man`
09-23-2015 10:37 PM
angel2794
09-08-2015 06:22 PM
FLAP
Camaros Wanted
09-02-2015 09:22 AM
hokis
08-09-2015 03:57 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: Grinding noise from torque converter or tranny?
