3.73's
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
3.73's
I want to get 3.73's for my 92 RS and what kind should I get .......what series carrier and all that......also....do I have an electric speedometer???? If so, how can I get it to where it reads the right speed?
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
You probably have 2.73 gears stock, so you'll need gears for a 2-series carrier. I recommend Richmond gears...they make a little more noise but they're much stronger.
Your speedo is electronic. How to make it read correctly with a gear swap, I don't know.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i think, THINK, that the electronic speedo is still driven from the tranny where the cable goes, by gears. if you get the right gears, the electronic sender, VSS, should be corrected as well.
I THINK. do a little searching, when i swapped gears i bought an aftermarket VSS sender, and an aftermarket guage. thats why im not quite sure.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, I know the 86-90+ firebirds electric ones use gears there so unless they changed it in 92 it is still the same thing.
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I have the Richmond 3.73 gears with an Auburn limited slip diff. I'm having the same dilemma with the speedo reading 15mph too fast at around 80 mph. Dakota digital has a speedo calibration box that should correct the speedo. It costs around 80 bones. Or you can also change the speedo gears in the tranny.
Car: '92 Camaro RS
Engine: 305 TBI
Somebody said 3.73's were too steep for a stock TBI but what's your opinion? Also, where can I get that calibration box at?
That's true for a stock engine because the factory cam is good for low to mid range torque. My engine makes it's power in the mid to upper range. The 3.73's compliment that and gives you eye popping acceleration. You can find the calibration box at http://www.dakotadigital.com/Detail....rtNumber=SGI-5 or there's a more expensive one here - http://dragonaero.com/SpeedChangerPage.htm
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
3.73s will give it ALOT more off-the-line grunt, especially with a low end torque kinda cam.. go for it
Kingtalon is right. Also the 3.73's will be great for your car. It's true that the stock tbi cam sux, but the nature of the tbi is that it doesn't die off in the upper rpm's like tpi does so 3.73 arent really too steep even for a stock engine. The stock tbi cam will probably peak at just past 4k rpm, but it stays flat until even after 5,000 rpm and doesn't really drop off so you can take advantage of the 3.73's.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
25THRSS is right but I think he was talking about built TBI's to TPI's in ease max rpm power. Because a stock TBI has a serious problem with high RPM unless it is cammed and pretty much stops accelerating past 4k. When it is cammed a TBI rev's vary well and would have no problem 'out reving' a stock TPI setup.
https://www.thirdgen.org/techbb2/sho...ghlight=dynoed
There is a dyno of a stock 305 tbi with exhaust and a chip. Everything else stock, for reference.
Transmission: 4l80e
Axle/Gears: 3.512
Eye popping, yeah, more like tire popping.
I can break em loose at 70+MPH by accident if i step down too hard. 3.73's are pretty harsh, especially if your actually making some power.
I like it
I like it
Originally posted by 05kcilS
i always read, 3.73's for manuals... and 3.42s for auto.... might want to look into that a little more. that's just what i read. i haven't had my gears changed yet.
Car: 2002 Z28
i love my 3.73s, i went with those because ill be going with a 350 and LT1 cam setup in a few years but they took about a half second off my ET (15.97 to 15.29 with 3.73s, posi, crank pulley, and tbichips.com's Stage 1 chip). As for the speedo, just go to the dealership at get some new speedo gears (2). www.700r4.com has a calculator that will tell you which ones you need. Do a search and you can get the part numbers.
Ok I have 3.27's I am thinking of swapping them to a 3.73's. My friends say that I will not see or feel that much of a difference. They say go 4.10's. But I do some 200 mile trips every so often and would like to keep the rpm's from soaring. I have a 87 GTA with a 700r4. Mods in sig.
The last thing you want to do if you do long trips like that is put 4.10 gears in there. With my 3.73's in 5th gear (.63 ratio) the engine is revving 2500rpm doing about 80mph. Fuel consumption will change big time.
Iam also thinking about putting 3.73's in my 700R4, my question is, how hard is it to do this, is it possible to do with just your everyday tools, I herd someone talking about how you need a press to do this??? Also same question about a TransGo Shift Kit.
Thanks I wouldn't do it myself. You cant do it with common tools and you must be right on or else your gears will be ****ed! Just pay a professional to do it for less than a couple hundred. It's worth it to have them set up right or you will regret it.
Thats kinda what I figured, My Grandpa races and he has a shop very close to where I live I can have him do it for free, that will be very easie considering he does have a hoist. Iam just sick of always relaying on him for it seems like everything, you know? What about the Shiftkit?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
