Tranny X-member bolt problem
Car: 85 T/A
I swapped out my tranny mount and torque arm bushing and when I went to put back my cross member one of the nuts inside the frame rail just spins. I have three tight but I don't know what to do with the one that just spins. Is 3 bolts OK? How can I tighten that one that spins? Thanks
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i would say 3 is OK but, that would kind of be considered a hack job, and well, hack jobs are sometimes reliable, but not so reliable other times. I would think its ok to use just 3. as long as its secure and the transmission is mounted nice and tight.
Transmission: 4L80E/4L80E
Stick an open end wrench up inside the frame to hold the nut while you tighten the bolt.
You may have to provide "access" for the wrench.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah if yhou cut access hole for wrench, yep
use box end of wrench
gotta do what you gotta do, i only have three of my X member bolts and im leaving it that way
will be fine
good luck
will be fine
good luck
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
