Broken tranny mount-pics!!!
Old Jul 25, 2003 | 04:51 PM
87GTA Runner's Avatar
Car: 87 GTA
Finally got around to checking the tranny mount just to be sure the bad clunking coming from the rear of the car was what I thought. Yup, the usual. GMs crappy rubber trans mount. I basically knew it was this because I was starting to feel the shifter move up and down. It is 100 times better now, I can step on the gas with confidence and no loud clunks. Swapped in an Energy trans mount.
Old Jul 25, 2003 | 04:53 PM
Car: 87 GTA
I assume this is how they usually break. Nothing out of the ordinary here, huh?
Old Jul 25, 2003 | 05:46 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
hehe, the carnage.........
mine just split in 2 the first time i opened her up. mine was the rectangular style though.
Old Jul 25, 2003 | 05:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
looks normal to me.
Old Jul 26, 2003 | 06:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
common, the bigger cars and the trucks use two bolt mounts instead of these single stud ones,
mine is busted in my 81 pickup. i can feel tranny come back down every time i let off gas when am accelrating in gear forward.
ill fix it one of these days, i have several good mounts laying around, but well time is worth to you alot during the good weather months... so you tend to do more importan things first and put off simpel things for later on and hope the simple things dont turn into hard things to do later
Old Jul 26, 2003 | 06:38 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I bet that caused some bumpy shifts.
Old Jul 27, 2003 | 07:21 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
That doesnt look like the stock mount to me. The original ones in both my cars are rectangular. My brothers friend changed his in his 87 gta. From the get-go his trans sounded like the mount was broke right after he put it in. I think it was made by Borg Warner. I gave him my old one after i upgraded to a poly mount. The car never made that sound again. He found out later that the mount was for V-6's. Dont know how much truth there is to it.
BTW, the mount he put in looked exactly like the one you have there, except new. It was very mushy to the touch, it felt like a nerf ball. And that was new.
Old Jul 27, 2003 | 07:28 AM
Car: 87 GTA
91, it very well could be the borg-warner you mention. I only got the car 2 years ago. So no telling what happened before that. As far as it being real spongey, I can't really tell because of the fact that it is in two pieces. I was expecting it to look like the replacement part though. Like you mentioned, the new one is rectangular and the busted one is more roundish.
Old Jul 27, 2003 | 09:51 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
thats probably a good thing. The one for my 1990 350 is rectangular the new one should last you a long long time.
Old Jul 27, 2003 | 08:10 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Mine looked exactly like that. Only I couldn't tell that it had broken until the second time I looked at it and actually lifted the tranny towards the body of the car and then I was able to see that it had separated. Cost 56 bones at the dealer for a new one. I hadn't noticed that Energy Suspension also had them for a little cheaper.
So.....I go on the highway after the repair, goosing the engine a little to get the feel of the new mount.....and passed a Washington State Trooper on the side of the road with a pulled over car. I thought he missed me as his view was blocked by a truck that I was passing. Negs,....was on me in a heartbeat. Asked me how fast I was going. I said "78" and I was testing a new tranny mount. He just said "slow down!", jumped in his car and was gone.
Old Jul 29, 2003 | 07:30 PM
biff85ta's Avatar
Car: 04 Vette
Mine cost $8 from advanced.
Old Jul 31, 2003 | 12:26 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Get a polyeurothane one from jegs or summit. They work damn good for about 25$ w / shipping.
Old Jul 31, 2003 | 07:55 PM
87t-5.0transam's Avatar
need some help....
im experiencing the same problems with my tranny. (clunking when i hit the gas to hard and the shifter rising about 2 inches) it just happened a couple of nights ago. if anyone has some helpful hints on going about a first time DIY fix i'd greatly apprieciate it
sheachopper
Jul 31, 2019 11:27 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 4, 2015 07:48 PM
