Cleaning up new rear end...need ideas...
Old Jul 28, 2003 | 05:17 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Okay, I got my 3:42's (the whole rear end, drum to drum), and it's an open carrier. I know I want to put a posi unit in, and I have a couple of questions:
Should I go with an Eaton posi or a Powertrax unit? They are both in the same price range, but which would be better?
and
If I just pull out the carrier, would I need to readjust the pinion depth or not...that part just makes me nervous....
Thanks in advance for lending me some advice!
:rockon:
Old Jul 28, 2003 | 07:18 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
There's no reason to pull the pinion out (unless there's slack in the bearing.) As long as you keep the shims straight and put them back on the same side of the carrier that they came from you'll be fine.
Old Jul 30, 2003 | 12:51 AM
lasher_350's Avatar
Engine: 5.7 L98
Good, that's exactly what I wanted to hear. Any suggestions of a good posi to go with? I've heard all the SLP ones...but I'm on a very tight budget, and it will be like wringing blood from a stone just to get a posi unit....let alone the axles to go with...
here's a pic of what it looks like right now....
lasher_350's Avatar
Engine: 5.7 L98
and.......
Old Jul 30, 2003 | 09:19 AM
mjpell's Avatar
rear end
I vote for the posi unit over the Powertrax. I've seen the effects of a Powertrax, and wasn't pleased. In fact, we took it back out and replaced it with a posi...
good luck,
Old Jul 30, 2003 | 09:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i very much like my eaton posi.
since i auto-x, the locker wasn't even a consideration for me, but if you are going for straight line only, it could be a good choice, but i have no experiance with one. but if you are concered about corning, and traction a good posi unit like the eaton is a good choice.
Old Jul 30, 2003 | 09:31 AM
lasher_350's Avatar
Engine: 5.7 L98
Good advice. My car is my only car and daily driver, so I bet the Eaton would be my choice then. Do they last long, and are the rebuildable when and if they wear out?? And can a normal guy with a decent set of tools swap one out while it's in the car? Thankx....
And I do want to corner well, so Powertrax is out.
Old Jul 30, 2003 | 09:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes they are rebuildable. as for how long they last, i have only had mine in for about 3k miles now, but eaton posi's have been around forever, so i assume they are fairly durable
Old Jul 30, 2003 | 06:58 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If you pull the carrier and replace it with another carrier, you can't just re-use the existing shims. You must set the back lash and bearing preload by using different thickness shims. This involves using a dail indicator and mag base.
If you have the hand tools and the indicator you can accomplish this with the axle still in the car. It's a pain, but can be done.
Do a search on this subject. It's been covered very well.
Old Jul 30, 2003 | 11:09 PM
lasher_350's Avatar
Engine: 5.7 L98
Thank you, alloy, I'll do that.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
