axel madness
Old Aug 3, 2003 | 12:13 AM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
axel madness
howdy,
is there a way to tell what axel gearing I have, given that I don't have the options sticker in the center console/glove box anymore?
For what its worth, its a 90 formula 305 TBI
Thanks!
Old Aug 3, 2003 | 01:25 AM
Kuejo's Avatar
Car: 1988 IROC
Not going to be your favorite answer, but if you're willing to pull the rear cover off, and count teeth on the ring and pinion, or look for the ratio staped on the outer edge of the ring (can't remember offhand if GM did it with the 7.625 or not - they did withthe 8.5's...) you'll be able to figure the ratio quite quickly. Just divide the number of ring gear teeth by the number of pinion teeth and you'll have your ratio.
Let me know if you find an easier way...
Old Aug 3, 2003 | 07:41 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: axel madness
Originally posted by MFaulkner
howdy,
Thanks!
" AXLE"
If you have a Auto Trans with the the 305 TBI your rear axle ratio
is a 10-bolt 2:73. Since this the most common set-up from the Factory. Or pull the cover on the housing and check the stamped numbers on the ring gear, more work for the same info.
hectre13
Dec 11, 2023 08:14 AM
Out-Cast
Mar 22, 2019 09:39 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Numbah-1
Brakes
Sep 21, 2015 05:18 AM
