Should my u-joints clunk MORE after being replaced?
Old Aug 3, 2003 | 05:55 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Last week I had my new pro-built tranny installed and new u-joints installed just for good measure. Theyh never clunked, but I've see the driveshaft fall off of 2 cars this year, so I'm kinda leary about mine on 160,000 miles. The new ones clunk a lot more than the old ones. Is this normal?
Old Aug 3, 2003 | 10:16 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
does it sound like a loud clunk right by ur seat? if so have ur trans mount checked out becuz it might be broken.
Old Aug 3, 2003 | 10:57 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
i agree with the tranny mount. if it constantly clunks then it may be your u-joints. u will know your tranny mount is gone when ur car is shifting and u hear a big thud sound on the bottom of your car.
just my experince anyway:lala:
Old Aug 3, 2003 | 11:55 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
sounds familiar
Could also be the torque arm bushing at the tailshaft of the trans....if the trans mount checks out ok.
Old Aug 4, 2003 | 03:58 PM
Mutiny32's Avatar
Brand new ES mount. Just had the TC, transmission, mount, and u-joints installed Friday. I'll check the torque arm. But my question is, why would it clunk more after they replaced all those things? Do they have to remove it or something?
Old Aug 5, 2003 | 05:55 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
yup...
Torque arm, trans crossmember ( and mount) all must be removed. Sometimes the two bolts that bolt up to the rear-end on the torque arm get loose and clunk a bit, they need to be torqued really tight. After doing that kind of work, you should at least get a Energy Suspension torque arm bushing, it firms the feel up a bit.
Old Aug 6, 2003 | 01:48 PM
Mutiny32's Avatar
whatever it is, it seems to clunk a lot when I use the shifter, like going into D, Reverse, or anything else.
Old Aug 8, 2003 | 10:14 AM
Mutiny32's Avatar
Alright, I've got a little bit more on the specifics of it.
It does it when I stop. Brake then stop. clunk. When I shift from park to any gear, sometimes when I take off.
Old Aug 10, 2003 | 05:22 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Mine does that too ever since its been rebuilt the first itme my tranny has been rebuilt 3 times so far. I have no clue why all the bushings were replaced and my tranny mount is poly.
Dan Hubbard
Aug 12, 2015 09:05 PM
BlackBoulder
Aug 11, 2015 11:15 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
