installing tranny filter and why
Old Aug 18, 2003 | 10:33 AM
Camaro-Bum's Avatar
fellas, fellas, need help with tranny filter question. why would i change filter and how do i know when and if it needs changing? is it as simple as it sounds? please give me some in and outs as to how to do this. thanks
Old Aug 18, 2003 | 11:06 AM
82camaro's Avatar
Car: 82 camaro SC
Most things I've seen show every 30000 under normal conditions. Why? Same reason you change the oil filer and air filter. The filter filters out the crap and eventually plugs or restricts. This can lower the line pressure and/or circulate the crap through the tranny. Tips: Do it when the tranny is cold and use a very large oil pan to catch the fluid--it doesn't have drain plug. Remove the filter AND the o-ring seal--it commonly stays in the tranny. Lube the new o-ring on the filter with some tranny fluid and install it. Install the pan and gasket, add 4-5 quarts of tranny fluid--check it while the engine is running and in park.
Old Aug 18, 2003 | 12:23 PM
ede's Avatar
ede
i use a soft face hammer to "seat" the filter. ditto on make sure you have the old o ring out.
Old Aug 19, 2003 | 02:58 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
hey dont check the fluid level intill you put it in all the gears for a couple of seconds like 4-7 then put it in park of course then check it if it needs more fluid turn off the car.And add a little less(better safe than sorry) than what you think it needs then check again intill its at the full mark.
Derick15
Sep 17, 2016 05:28 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
