3.42 or 3.73
Old Sep 8, 2003 | 09:27 PM
SeanTimothy's Avatar
3.42 or 3.73
So i have ported polished 416 heads on a carbed 91 rs. It is basicly set up for high end power, i have no real low end power at all. from idle to 1500 i have nothing....bad launches and all.
so here is my delima. 3.42 or 3.73. this is a daily driver , also an automatic.
What GM cars/trucks came with 3.42 and what came with 3.73s?
Old Sep 8, 2003 | 09:36 PM
idrag2's Avatar
I had both in my car...............3.42 were cool, but 3.73's rule.......don't kill you mpg either. 70@2500
Old Sep 8, 2003 | 09:45 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Get a 3.73. Will helpwith no low-end grunt. 3.42 will make your launches WORSE than 3.73.
Options when I ordered my car were 3.23 or 3.73. I believe 3.42 came along later. (87-89)I could be wrong.
Old Sep 8, 2003 | 11:20 PM
Well i know that 3.42 wont give a better launch than a 3.73. but im wondering if the 3.73 will travel too fast through my power range and hurt more than it will help. That is why isuggested the notion of a 3.42
At what guesstimated MPH will i be at by 5500 rpm in first gear with the 3.73 Vrs the 3.42
i was thinking 27 with the 3.73
and 30 with the 3.42
Just a guess.
Old Sep 9, 2003 | 03:09 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
With my 5-speed, 1st gear tops out at about 40 MPH.
Old Sep 10, 2003 | 12:41 AM
really? i hit 40 in first with my 2.73s and 700r4
Old Sep 10, 2003 | 05:13 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
1st gear on that 5-speed is almost a "granny". I can take off from a complete stop in second.
Old Sep 11, 2003 | 02:10 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
http://www.f-body.org/gears/
That will tell you everything you need to know about tranny/rear/MPH relationships.
Old Sep 11, 2003 | 06:34 PM
Pro Built Automatics's Avatar
I would do a torque converter change long before I would do a gear change. A 9.5" TC with the right stall will work with either gear and you will save money and give you more of a performance gain. A 3.42 to a 3.73 gear change is almost imperceptible by itself.
Old Sep 11, 2003 | 07:28 PM
i have a 2500 stall tc.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
dbrochard
Jan 28, 2016 08:42 AM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
