anyone using a Spec Clutch???
Old Sep 15, 2003 | 07:52 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I finally torched the Centerforce DF after 2 years, 15k miles and about 65 passes on slicks....
so needless to say i have no complaints about it at all....but im kinda in the mood to try something different....and I like the application specific stages of clutch disks that SPEC offers......but i dont know anyone who has one or had one.....
so lets hear it...
Old Sep 16, 2003 | 08:31 AM
DanS's Avatar
I put a SPEC Stage 3 in my 98 Z28 a few monthes ago. There's a lot of people on the ls1.com boards running them. So far, I'm pretty happy with it. The grip is amazing, but it chatters a little bit.
I don't know of anybody using in them in third gens, though.
Old Sep 16, 2003 | 07:01 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I have a Spec stage 3 feeding the T-56 in my '91. It's been there for 2 years and 30k miles and I absolutely LOVE it. It does chatter once in a while...mainly when backing uphill or trying to "ease" the car into a certain position. When you're out on the street it doesn't chatter at all. It also doesn't slip at all....very "grab-and-go" when you dump the clutch. I highly recommend them.
The biggest reason I got one to begin with was that their shop is about 20 min from me and I was trying to get the swap done that weekend and hadn't ordered a clutch yet. I went over there on Friday afternoon and payed cash.....they loved seeing that!! Now I'm hooked on their clutches.
Old Sep 16, 2003 | 07:45 PM
Car: '91 Camaro RS
sounds good.....alot more positive than negative feedback about spec....
i ordered a stage 3 this afternoon and it should be here by the end of the week......not bad pricewise either at $329
Old Sep 25, 2003 | 05:52 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Do you mine sharing where you got it from? I need to get one this week.
Tom
Old Sep 25, 2003 | 06:01 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Nevermind, I think I know where you got it from. I forgot that you got the 5 speed clutch and i'm shopping for a t56 clutch. That explains the $200 difference that caught my eye.
Old Sep 25, 2003 | 07:01 PM
Car: '91 Camaro RS
lol thats alot, its probably a larger pressure plate and clutch disc.....most of those belhousings fit 11" setups
Old Sep 25, 2003 | 08:18 PM
TheGreatJ's Avatar
It's pricey because it's a unique design. The '93-'97 T-56 uses a pull-style clutch where the clutch fork actually pulls the pressure plate away from the disc instead of pushing the throwout bearing into the "fingers" which use a lever action to pull the plate out. It's a good design but it's a little rough on throwout bearings. They tend to whine after a few thousand miles.
Old Sep 25, 2003 | 10:22 PM
AustinT's Avatar
I have a stage II behind a zz430 crate works great no chatter fully streetable
Old Sep 30, 2003 | 07:43 AM
91n99fbodies's Avatar
Car: 91z28
Engine: LB9 305TPI
whats the pedal pressure feel like? the stock clutch (well whatever clutch is in it, 120k miles) has a very very stiff pedal, requires a lot of pressure. my girlfriend drives the car 90% of the time, so if the pressure is lighter than stock thats a plus. I had a spec in my 99 before the auto conversion, and with the adjustable master/slave, the pedal pressure was extremely stiff, i dont want this for the 91.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
