rear end linking from the yoke.
Old Sep 18, 2003 | 10:16 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i went under my yesterday to check everything out and grease the LCA's and panhard rod.
i hoped in the pit asnd i saw that i have a ring of gear lube right around the tranny tennel covering evrything that is aligned with the yoke.
what is leaking and how easy is it to fix.
Old Sep 18, 2003 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's the pinion seal.
Not too hard; mark the position of the big nut, remove it, pop the yoke off, change the seal, put the yoke and nut back on, tighten the nut just barely past where it was (like 1/16 turn farther or so). The nut is 1¼", and it takes in the neighborhood of 200 ft-lbs of torque to deal with it. No big deal.
Old Sep 24, 2003 | 09:55 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright, I have the exact same thing, and I going to try and fix it tomorrow. Big nut, will I realize which one when I am down there? Is this just taking in to count you need to remove the driveshaft first?
Old Sep 25, 2003 | 05:24 PM
Engine: peanut LB9
yes. you do have to remove the driveshaft 1st
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
hectre13
Aug 26, 2015 08:17 AM
