2.73 to 3.73 Should i do it?
Old Sep 19, 2003 | 09:36 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
i have the 2.73 gears in my posi drum rear. this is an 87 z28 with 305 lb9 tpi. i was wondering if i should swap gears to 3.73 and what i would need to do it and how hard would it be to switch to disc rear brakes at the same time? i am looking for something to do over the winter and i want to start improving my car now that it is running good (knock on wood).
Old Sep 19, 2003 | 09:51 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
try 3.42s, theyll work out better.
Old Sep 19, 2003 | 10:28 PM
Kevs87Z28's Avatar
Engine: 355 Carb
why those?
Old Sep 19, 2003 | 11:09 PM
25THRSS's Avatar
well first you need to find out where your peak power is then you need to find out what trap speeds you will be pulling then you can decide on the optimum gear ratio for your car.
Old Sep 19, 2003 | 11:16 PM
Kevs87Z28's Avatar
Engine: 355 Carb
well im basically stock besides a shift kit (i think), ported plenum, k&ns, and an airfoil. but i am looking to get the car into the mid 13s. i dont know how to go about that in a cheap way but thats what i want to do eventually.
Old Sep 20, 2003 | 07:47 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
3.73's arent very fuel friendly and will rev the engine higher... Give 3.42's a try... right now I am going to be puting in a new Posi disc 3.27's from my old 2.73's drums...
Old Sep 20, 2003 | 08:08 PM
Kevs87Z28's Avatar
Engine: 355 Carb
i want disc brakes mostly. i dont want my fuel mileage to suffer at all. can i just go up a ratio and put discs in? how good are these 3.27s?
Old Sep 20, 2003 | 08:44 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
I will be putting them on my car soon. I will let ya know.
Old Sep 20, 2003 | 09:29 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
i went to 3.27s from 3.08s my gas mileage is the same if not better. driving like a nut around town i get 16mpg, if i really want i can get around 18 or 19 if i go easy and normal, on the highway ive seen around 30. this is great for a mid 13 sec car no doubt. ill be going to 3.45s for next season and i doubt itll hurt my mileage any and even if it does i got plenty to spare haha.
JSDaddy189
Sep 26, 2015 03:50 PM
64Chief
Sep 12, 2015 08:05 AM
whyt86roc
Sep 10, 2015 10:03 PM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
