g-force kit vs. retro fit t56
Old Sep 23, 2003 | 06:08 PM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
As i was reading in the search i came along both of these options. Now i will be putting the zz4 crate motor and as i have learned the t-5 can't handle it. So i figured t-56 but i also learned about the g-force t-5 up grade kit that can handle up to 400 or 600 horsepower. I was curious what would be better for my engine, the zz4 crate engine, and was curios t-5 rebuild or t-56 retro fit?
Old Sep 27, 2003 | 01:40 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I have the retrofit T56 and I am pleased with it. One thing to consider is that with the T56 you will have two overdrive gears, so you can run lower gears and still maintain decent rpms cruising at highway speeds.
Old Sep 27, 2003 | 02:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
rather then a beefed up T5 or the retrofit T56, i like the stock LT1 T56..... *shrug*
Old Sep 27, 2003 | 10:08 PM
laiky's Avatar
i would go to the t56 but keep in mind you will probably want to go 3.73 or 4.11 to off set the taller first gear.
Old Sep 28, 2003 | 05:05 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
The aftermarket T56 is geared numerically higher than the LT1 T56. I think the first 4 gears are similar to the T5 gear ratios, but double check on that. I know first gear is roughly 2.97 vs. the 2.66 1st gear in the LT1 version.
If he already has a T5, the aftermarket T56 is pretty much a direct swap. It only requires cutting back the torque arm 2", which can be done with a hacksaw or cutoff tool, and having the driveshaft shortened 2" (cost me $40).
I'm not saying that you shouldn't go with the g-force T5, I just have no experience with that transmission.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
