Replaced entire Hydro setup, bled and bled clutch still wont disengage
Old Sep 28, 2003 | 02:31 PM
91rsklown's Avatar
I have tried a search and done everything i can to try and get my clutch working again, but no luck. I have bled the system so much it's not funny.
I replaced the slave cylinder first, then the master. I keep bleeding and air keeps coming out of the bleeder every time i open it. clutch goes in, bleeder opens, air and fluid comes out, bleeder closes clutch goes out. over and over. But I always only get like a 1/2" of travel on the fork. I adjusted the screw on the fork all the way out and all the way in and the clutch won't disengage. I don't see any leaks from the lines or the resevoir. Could there really be that much air or is there somewhere that will let air into the system w/o leaking fluid??
Thanks for any help,
Clint
Old Sep 28, 2003 | 04:01 PM
ede's Avatar
ede
suspose to let the slave hang at a 45* angle and gravity bleed. i never had any luck with the gm method. you can buy a completeMC, slave, and line assembly prebled from gm. i use a pheniox injector to bleed clutch systems
Old Sep 28, 2003 | 05:17 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
what i did with mine was to push in the pin that comes out of the slave cylinder to bleed it, then i did the pedal side next, worked awsome that way
Vintageracer
Jan 10, 2020 05:33 PM
86White_T/A305
Aug 17, 2015 12:16 AM
ChevyZ71
Aug 13, 2015 07:30 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
