9 bolt series 2 gear set of 3.73, 3.91 or 4.10?
Old Oct 6, 2003 | 10:50 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
What gear ratio would you prefer for your series 2 9 bolt? This would be a gear set that would mount directly onto the existing series 2 carrier.
Options are
3.73
3.91
4.10
Miles
Old Oct 6, 2003 | 11:08 AM
SLP_GTA's Avatar
being a Mopar guy
3:91 but 3:73 would seem to work best overall. Hey Miles is 3:91 to much gear for an 700R4
Old Oct 6, 2003 | 12:37 PM
cdartz's Avatar
3.73 is the max I'd go with a 700R4
3.91 would be good for a T56
4.10 I think is too much gear when it comes to overall drivability.
Old Oct 6, 2003 | 07:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
3.73 is good for no OD (ie. TH350, TH400)
3.91 is prolly good for a 700R4
4.10 is good for a T56... i've heard of 4th gens with 4.56 gears and still have low highway revs.
Old Oct 6, 2003 | 08:30 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
pretty much what everyone else said, i was wondering tho if there will be a 3.55 gear set available, i know theres 3.45s already available, but J/W.
Old Oct 7, 2003 | 08:32 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Luckily, I already have a 3 series and I bought some 3.91's off a guy on here who never put his in.
I'm just waitin' on the support cover and that solid pinion spacer kit.
Although I have 3.91's, I think 3.73's and 4.10's would be the most marketable.
Old Oct 8, 2003 | 08:31 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
3:73
I have a 3:73 in my T/A, a built 700R4, and a built 355 with a wieand stealth intake, a CompCams 280H, 9.4to1 pistons etc. and I really like the 3:73, I am glad that I chose it over the 3:42 that I was looking at.
Old Oct 9, 2003 | 07:06 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i went with 3:73's aswell, i'm very happy with my choice
Old Oct 13, 2003 | 04:18 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Any info on when/if these will be available? I would love some series 2 3.73's and don't want the series 3 carrier and new gear set price...
Old Oct 13, 2003 | 09:30 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I need a lot more serious interest than this before I make a special set of gears
Miles
Old Oct 14, 2003 | 09:14 AM
bnoon's Avatar
What are the minimum numbers?
Old Oct 14, 2003 | 10:40 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
i think id like 3.73s
any estimated price on it?
Old Oct 15, 2003 | 06:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
3.73
Not to much gear - not to little
Do you realize how many guys with a factory 9 bolt series 2 carrier would rather upgrade just the gear instead of the gear AND the carrier !!
You have to consider all the guys out there that got the highway 2.77's in thier IROC's and Trans Ams that would take advantage of a "real" series 2 gear. Don't worry about the guys swapping T56's into thier car - they are the exception in the market.
You want to make a gear that guys with "factory" set-ups will buy ! Since the factory usually put the 2.77 gear in the 700R4 equiped cars. Make a gear that will compliment those cars ! My opinion is the 3.73.
I'm sitting on a 2.77 9 bolt and had NO plans for it other than parts if needed...... If I can get a set of "real" gears for it I might just restore it !
Old Oct 15, 2003 | 06:48 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
id rahter have 3.55 ratio then 3.45. being in my freinds mustang which is equipped with the 3.55s gears they are "perfect" for the particular setup.
hectre13
Dec 11, 2023 08:14 AM
1984HO
Mar 19, 2021 11:59 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
