9 Bolt Rear
Old Oct 7, 2003 | 10:22 AM
conlinj's Avatar
9 Bolt Rear
I'm going to look at 2 9 bolt rears. Without opening it up and counting the teeth, how can i tell the gear ratios that they are? Is there a tag or code stamped on an axle tube, and if so which codes are for which ratio? Thanks
The one is a 3.27 rear from a 1 owner GTA with 68,000 miles on it so I think i can trust that guy, but I just found another that said it's from an 88 with a 3.23 ratio (not avail in the 9 bolt that yr, could have meant 3.27) with 78,000 miles, I just want to be sure that what i'm looking at is what I want and don't end up with a 2.73 rear. They are both out of the car
Old Oct 7, 2003 | 11:31 AM
ede's Avatar
ede
look for the ratio stamped on the gears, sort of the same as counting teeth, but not quite
Old Oct 7, 2003 | 12:24 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
why not pull the cover off? its easier then tryin to figure out how many rotations ur pinion is going.
Old Oct 7, 2003 | 12:36 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
If the axles are in it, a simple (but not very accurate!) way to do it would be to spin one of the axles one revolution and count how many times the pinion yoke turns.
Old Oct 8, 2003 | 10:30 AM
conlinj's Avatar
Well it's not my rear yet, i'm going to look at them, that's why i wouldn't want to pull the cover off, especially if i don't end up buying it from that person
Old Oct 8, 2003 | 02:19 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
if their forsale the owner shouldnt have a problem with pulling the cover off for you, unless theres somethin to hide.
Old Oct 8, 2003 | 03:11 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
The "turning the wheel and counting the shaft turns" thing did not work for me, I don't know why. Pulled the cover and counted the teeth - it was real simple.
Old Oct 8, 2003 | 09:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
u dont even need to count on the BW rears, the ratio is stamped on the ring gear and the pinion and ring teeth count is also stamped there to.
Old Oct 10, 2003 | 01:42 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I purchased a rear-end from IROCK88 awhile back. Before I handed over the money we pull the axles out so I could make sure it was a 28 spline axle rear end. I kinda felt bad but he didn't mind. I knew for a fact it was a 28 spline after that and I handed over the money.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
