What trans would I need?
Old Oct 18, 2003 | 01:21 AM
SweetRide45's Avatar
What's up guys? Well, I'm converting my '90 3.1 to TPI and adding a sdpc crate engine. So far, in mind, it's going to be this:
http://www.sdpc2000.com/cart.asp?act...=1577&pid=9009
Now, w/ that engine, what 700R4 would you recommend? I don't want to spend a fortune on it, but also want it to take what that engine can deliver.
Also, would my stock differential hold up to it? What would I need to do differently to it?
Thanks for the input/idea's!!!
Old Oct 18, 2003 | 01:42 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I'll recommend a Pro-Built Street/Strip 700-R4. It can handle up to 550 hp, comes with a Trans-Go Shift Kit and a Vette servo.
I just installed mine 2 weeks ago and I absolutely love it. :hail:
Also, Dana was able to answer any and all questions that I had.
www.pro-built.net
Old Oct 19, 2003 | 03:00 AM
Would that trans be hard on shifts? I heard it shifts smoothly when you gradually push the throttle...but if you JAM it, THEN it shifts hard to chirp the gears...Is this true? I would find it somewhat annoying if when drivin' "normally", it would be shifting in a jerking manner.
Thanks!
Old Oct 19, 2003 | 04:28 PM
Its not really hard on shifts...if it shifts below 3500-4000 RPM, you almost don't even notice it shift. However, if you hold the throttle a little harder and it doesnt shift till above 4k, then its pretty firm...enough to throw your head to the back of your seat if you werent expecting it. It is nice because if you drive it normally, it acts like a stock tranny or smoother. But its a whole different ball game once you get on the gas
Old Oct 19, 2003 | 11:56 PM
Would I need to get any type of torque converter to go w/ that package? I don't know anything about them, and don't know what I would need if I had to get it. Any insight on that? Or, would I just get the trans and bolt it up right to the new engine? Or, does that trans COME w/ a torque converter?
Old Oct 20, 2003 | 10:24 AM
Yes, you will need a 30 spline converter for the transmission. If you're interested in going that route, your best bet would be to call Dana @ Pro-Built and tell him the engine you are getting (have the specs ready...) and he will recommend the best converter to work with the engine and transmission.
Old Oct 20, 2003 | 10:47 AM
Sounds good. I will talk to him and see what he says. That's probably the best bet I should go w/, correct? Should I get a trans cooler too? Different Trans mount? Or, could I use the one from my 6?
Old Oct 20, 2003 | 11:59 AM
I would recommend getting a tranny cooler. They're relatively cheap and easy to install. Its just cheap insurance.
I'm pretty sure the transmission mounts are the same, so as long as its in good shape you could probably use it. But with the power you will me making, if the mount you have is stock, it is probably wise to invest in one that is stronger like an Energy Suspension polyurethane one from Summit for like $20.
Old Oct 20, 2003 | 12:02 PM
ok, thanks a lot. I appreciate your help. Looks like I'm going to get ahold of Dana and see what I'll need :-D
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
