700r4 problems
Old Oct 18, 2003 | 07:59 AM
poetic's Avatar
Car: 1988 red iroc 1984 burnt orange Z28
Engine: 1988 5.7 vortec modified m.a.f. sensor gutted boxes 1984 5.0 ho totaly stock & flawless
Transmission: 1988 4 speed auto. w/b&m pro shifter borg warner 9 bolt w/3:27 gears 1984 5 speed borg warner
700r4 problems
hello all hope you can help i have a 1988 iroc w/ 350 vortec i have been through two 700r4's since i bought it . both lost 3 and 4 gear fluid looks good can any help me w/ this problem please ?
Old Oct 18, 2003 | 08:16 AM
poetic's Avatar
cont.
sorry guys guess telling you what it is doing may help . okay the tranny shifts fine first and second but when it hits third it revs like it is in nutreul same if i am in od even if manually shifted hope that helps you out so you can help me out (pulling my hair out on this)
Old Oct 18, 2003 | 05:35 PM
Pro Built Automatics's Avatar
This is common, 3-4 clutch packs in the 700R4's do not have the capacity needed to last under HD or Street/Strip conditions. I have solved the 3-4 clutch problem, along with many other things in these units. If I can be of help let me know?
Old Oct 18, 2003 | 11:06 PM
poetic's Avatar
700r4
:hail: whew now that i know what the problem is can you suggest what i need to do to fix the ptroblem ? does it need a rebuild and would it be worth it ? i do have a b&m pro shifter bolted on it thank you for your reply you have saved what hair i have left ! :hail:
Old Oct 18, 2003 | 11:44 PM
Go to http://www.pro-built.net/index.cfm?f...t&productid=35 if you are interested in a complete transmission. If you want to build it yourself, I carry the right parts for this transmssion.
Old Oct 19, 2003 | 12:43 AM
poetic's Avatar
akkkkkkkkkkkk!@!!
is there a doctor in the house? I wish I could afford that if only i had listened to myself when i first bought it I was ready to buy a brand new B&M 700r4 but stupid me listened to a freind and went the complete oposite way w/ a used one well guess where I am ?
up the puverbile sh*tsriver to bad i had the money to do it to great site have favorited it . and again thank you for your reply and lettingme know what the problem was w/ it I apretaite maybe now i can get my baby on the road I think i am stating to have withdraw syndroms if i don't atleast sit in it once a day for a few minutes will it runs i start shaking anyone else having this problem? Heheheheeheheee thanks pro thanks 3rd gen.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
