Rearend...
Old Oct 20, 2003 | 07:47 PM
Prostreetcamaro's Avatar
Car: 1984 Chevrolet Camaro
Engine: (Currently) 305 SBC. (about 250 hp)
Transmission: B&M 700R4 fully built, with a B&M 2500 Stall Converter
Rearend...
Hi, I have a 1984 Chevrolet Camaro which currently has a slightly modified 305 in it... I am Squeezing out about 250 hp, but I am still not satisfied... so I am currently building a 383 stroker... Fully modified... AFR heads, etc... Very nice!... My car currently has the stock 7.5" Limited Slip rear in it... now... I am just Guessing, but won't the torque from the 383 pretty much split the carrier in half??? I am also gonna be spraying on the motor too... and I expect to have pretty good traction... now my question is,I have a chance to get a built up 10-bolt from a 1994 z28 which had an LT1 in it... it had an auto tranny, etc... the old motor was making 500hp at the wheels with this rear, and it gripped Excellent in the z28... he ran (Maybe) 4 times with this rear after it was built, and this was just in the 1/8'th mile... the car was going over a bridge and cought some air and slammed face first into the guard rail at speed... I have inspected the entire rear and all and it is OK... It has Wilwood Disk Brakes on it, it has 3.73 gears, with an Eaton Posi Unit, and Moser Axles... Because the guy was my friend he is only charging me $500 for the entire rear... disks and all... and he is getting rid of it so cheap because his wife is having a baby and they need the money... I was wondering if this would be worth $500...(I think so)... and will I have to get a custom driveshaft to fit the Rear into my 84....
Thanks for any help....
Old Oct 20, 2003 | 08:11 PM
Bandit5's Avatar
Yeah, it is worth $500, at least until it blows, then you know you need a 12-bolt or 9". The stock driveshaft will work, but you shoudl replace the u-joints anyway and might want to have it balanced. Personally, i wouldn't take any chances with the drivetrain, I'd get a custom driveshaft made. I get my custom driveshaft next week.
Old Oct 21, 2003 | 01:53 PM
Well I was planning on using the driveshaft from the 84 for the z28 rear... that way I know it is balanced, because I drive the car quite often...
Old Oct 31, 2003 | 10:19 AM
matt shutt's Avatar
Car: 84 T/A
Engine: 355
Transmission: t5
that is exactly what i want to do to my 84 TA do you have any ideas on how to hook up the e brake cable to the disk brakes im sure it has to be different
Old Oct 31, 2003 | 03:20 PM
M84Z28's Avatar
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
I would make sure to get a driveshaft loop too though.
87iroczeh
Jun 30, 2011 08:10 PM
twistedfaith17
Apr 12, 2011 12:13 PM
Bullydawg
Southern California Area
69
Sep 14, 2010 09:46 PM
AKATDOG
Jul 28, 2010 03:38 PM
flexxedout88
May 2, 2010 04:27 PM
