wiring help needed from auto to t56 swappers
Old Oct 25, 2003 | 12:47 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
ok, if you look at the picture i have posted, youll see the wiring harness doohicker that was on the auto shifter. i need to know what all the wires are and where to wire them so that everything works as it should. reverse lights, neutral safety and whatever else those wires might be.
call the wires:
#1 - the big aqua with the white stripe
#2 - purple
#3 - green
#4 - blue
#5 - orange with black stripe
#6 - black with white stripe
so...
what are wires 1,2,3,4,5, and 6?
thanks alot for your input. i need to get all this taken care of in order to pass inspection.
<img src="http://web.njit.edu/~mtp3/media/consolewires.jpg">
Old Oct 25, 2003 | 05:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
#3,#4 are the rev. lights, I would check the wiring around the pedals for a plug in connector for your neutral safty switch that is mounted on the clutch pedal. other wise it should be the #1/#2
Old Oct 25, 2003 | 05:29 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thanks, any ideas on #'s 5 and 6?
Old Oct 25, 2003 | 05:54 PM
Engine: ls1, LB9
I will check in a few. what year is you r car again? it does not show when I am in this screen
Old Oct 25, 2003 | 06:07 PM
Engine: ls1, LB9
it shows them as B)-orn/blk...and A)-blk/wht... both are connected in park and neutral only used in auto only. I never used them when I did my swap and I don't think any one else has?
Old Oct 25, 2003 | 06:21 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
my car is an 89 IROC.
so what should i do with them since they arent used?
thanks for the help!
btw , where did you get the info from?
Old Oct 25, 2003 | 09:18 PM
Engine: ls1, LB9
I got the info for a 91 camaro manual. on my 88 I just left them alone never hooked anything up to them
IROCZ1989
Jan 24, 2016 03:55 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
