Shifter Knob Removal
Old Nov 9, 2003 | 09:00 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Shifter **** Removal
Replacing carpet and need to remove center console. I cant figure out how to get the thing off. Its the black ball kind if that makes any difference.
Old Nov 9, 2003 | 10:14 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
it should just be threaded on. I've seen some get tight so you might have to give it some muscle.
Tom
Old Nov 10, 2003 | 12:11 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
If its an automatic, you have to pull off the button first. I used a pair of channel lock pliers to do this. After you get this off, there is a c-clip that holds the ball to the shift lever. Remove the clip and the ball should slide right off.
Old Nov 10, 2003 | 01:00 PM
Bandit5's Avatar
Uhhh... back when I had the stock auto shifter, all you had to do was remove the C-clip on the front of the ****, then pull on the **** while pushing the button and it would come off. I used to take out the platic thing inside as a cheap method of theft prevention.
Old Nov 10, 2003 | 01:12 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
HA! That's good cheap anti-theft... My c-clip wasn't seated properly - didn't even know it was there (smack!) so I had to make sure I didn't accidentally yank the stinkin' handle off the shifter every time I used it. Found the clip, said "Oops," and that problem went away...
Old Nov 10, 2003 | 05:02 PM
Car: FBODYS
Engine: ALWAYS 8'S
Thanks for the clues
Probably go out tonight and get it taken off. Im stuck at school right now. Once again thanks for the info.
Old Nov 10, 2003 | 09:42 PM
Oh really? Maybe they changed them? On the shift **** on my 82 the only way to access the clip was to take the button out first....
Old Dec 9, 2007 | 04:26 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
Re: Shifter **** Removal
wat about the newer style, liek on the 89 iroc z i got the button off and the spring but the rest wont budge, i didnt want to fu anything up so i didnt pull as hard as i could
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
