Changed my gears can't go over 95mph
Old Nov 11, 2003 | 11:46 AM
92z28conv's Avatar
Car: 1992 Z28 Convertible
I just had someone install an eaton posi carrier with 3.23 gears on my 92 z28, but on the freeway it stalls max top speed is 95mph how can I have my z28 get more top end mph
Old Nov 11, 2003 | 12:11 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
is it hitting the speed limiter? sounds like the car is limited at the factory 112mph, and with the gear change that is now 95.
Old Nov 11, 2003 | 12:30 PM
87Formula4bbl's Avatar
Car: '87 Formula
1. Get a custom burnt chip to disable the speed governor
2. Put the correct transmission speedo gear in and have your speedo calibrated correctly.
3. Get the kickdown cable that allows WOT in OD (assuming you have auto). This wont fix the problem though until you get the governor overridden, only allow you to take more advantage of your OD with those gears.
Recommended: all of the above.
Old Nov 11, 2003 | 01:05 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I have a Hypertech chip that would at least raise your top speed, if anything.....
Old Nov 11, 2003 | 06:31 PM
92z28conv's Avatar
where can i get a custom burnt chip to have my z28 go over at least 140 mph or more
Old Nov 11, 2003 | 06:34 PM
92z28conv's Avatar
thanks guys for the info
Old Nov 11, 2003 | 07:07 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
if you want a temporary fix so you can go faster than 95...until you get the speedo calibrated correctly....
just splice a toggle switch into the VSS sending unit wire on the transmission, shut it off....no signal to the ecm, no speed limiter
Old Nov 12, 2003 | 07:05 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
You want an upshift valve. The "kickdown" as he describes it is only the TV cable, and there is only one TV cable and it does it's fuction.... telling the trans how far open the throttle is.
Old Nov 12, 2003 | 07:25 PM
Car: '87 Formula
Sorry, what I MEANT was the WOT upshift kit (no downshift at 2/3 throttle). Sorry!
Old Nov 12, 2003 | 07:36 PM
Straight out of the TGO FAQ
Q: Why won't my automatic tranny shift into overdrive at wide open throttle?
A: It's designed not to shift into overdrive if your foot is all the way to the floor. You must be at 2/3 throttle or less before the tranny shifts into OD. So when you hit the top of 3rd gear, you'll have to let off the gas to allow for the shift. But putting your foot back into it will probably cause a downshift resulting in the same problem.
B and M makes a kit modified kickdown valve (part # 70237) which fixes this problem. It costs about $30 and can be ordered through the Summit or Jegs. GM also makes a modified upshift valve which it included in police packages and that part # is 8673948 and sells for around $15. This will allow the tranny to shift into OD at full throttle.
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
Warlocksirix
Sep 3, 2015 12:26 PM
jbd1969
Aug 17, 2015 07:06 PM
