best clutch possible
Old Nov 19, 2003 | 06:50 PM
johnny82vert's Avatar
Car: 1993 SSP mustang coupe/1982 Z28 convertible 5.0 5spd.
well I finally got my 82 camaro (converted to an 89 IROC vert back in 1995) back from the body shop and now I am going to have my mechanic drop in my 383 stroker motor from my truck into the camaro within a week or so. Now I would like to change the pressure plate, flywheel and clutch with the best possible products in the market. which combination would you guys recomend. the engine puts roughly 390 hp to the flywheel when dynoed on my truck. I know I know the ****ty 7.5" 9 bolt rear won't hang. thats comming a little later as the funds become available.
Old Nov 19, 2003 | 09:29 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Personally I'm a fan of the Centerforce Dual Friction clutch setups. I've got one in my car behind the 350 with the 6 speed and I have no complaints about it whatsoever! I'm sure you'll hear different opinions from other members, but I'd go with the Dual Friction setup! Also, do a search of the forums, because this question is asked fairly frequently and you can get some ideas from previous posts. Good luck!!!!
-Paul
Old Nov 20, 2003 | 01:14 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
What about the best clutch for a T5??? I keep buying GM clutches, but they only seem to last a couple of years. The first clutch I replaced was the factory clutch.
Old Nov 20, 2003 | 06:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i'm running a centerforce DF i'm very happy with it (over a year on it now) next time, i think i am goign to try a Spec, i have heard many good things abotu their clutchs also.
Old Nov 20, 2003 | 06:50 AM
GTA4ME's Avatar
Do you have a website for them?
Old Nov 20, 2003 | 07:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
http://www.specclutch.com/
Old Nov 20, 2003 | 07:27 AM
-Paul
I also have to consider to replace the radiator and go with electric fans, the setup you have with the be cool radiator and the lt1 fans, how does that work for you? the lt1 fans are they after market or the factory fans for the 93-96 camaros? and what did you pay for that setup?
Old Nov 20, 2003 | 07:49 AM
quadgoat's Avatar
Car: 1992 Firebird
So far I've been very happy with how the Be Cool radiator and the LT-1 fans have worked out. At first I was disappointed in the Be Cool because the car was running too hot, but then I got the air dam installed and it did reasonably well with the original single fan and no shrouding. I got the LT-1 setup (stock, off a '93-96 F-body) off of ebay with the wiring pigtails for $75 including shipping. I've been told that this fan setup flows more CFM than almost any aftermarket setup you can get, and it seems to work quite well on my car. Cruising down the highway I usually don't see temps higher than 195 or so (I have a 180 t-stat) and on the hottest days in the city I MIGHT get up to 220, but as soon as I come to a stop light and idle for a while the temp starts dropping back down. I still wish there was a way to get my car to cool without having to constantly depend on the fans, but it does seem to work for now. If you search through my old posts you can find some information about the LT-1 fan install and stuff like that. If you have any other questions feel free to ask!
-Paul
Old Nov 20, 2003 | 07:30 PM
ScreaminDeamin85Z's Avatar
i like my clutch alot, i think that the press plate helps quite a bit also
Old Nov 20, 2003 | 11:05 PM
laiky's Avatar
love my CFDF
Old Nov 21, 2003 | 09:42 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
The best clutch out right now is the mcleod twin street but at $1200 it isn't cheap. Look at what all of the 4th gen guys are running, either spec, mcleod or slp.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
