Shift an 700r4 auto out of 2nd manually?
Old Nov 21, 2003 | 03:00 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
I have an 88 TA 5.7 w/ 700r4 auto tranny. I can manually shift out of 2nd gear, but not at wide open throttle.
Going down the track I feel that second gear is holding itself in a little to long. No matter when I shift the selector out of 2nd, it decides for itself when to shift. And, no holding it in second is not going to help because it's accidently happened a few times and usually hurts me by .2-.4 because I cross the line at close to 6k if I stay in it.
Is this normal? Is there a way to adjust something to make it shift sooner out of second without messing with where it shifts out of 1st?
Old Nov 21, 2003 | 03:55 PM
Pro Built Automatics's Avatar
This is a common complaint of the 700R4 not making a 2-3 WOT shift. (1) It starts to happen with age (less holding power at the 3-4 clutch). (2) The 3rd gear feed hole is on the small side to start with. You acn fix this (if the 3-4 clutches are still in good shape)(1) By adding a Corvette servo you can get more oil to the 3rd gear clutches. (2) Add the larger boost valves (main & intermediate). (3) Add a Trans-Go Performance Shift kit (this will triple the oil to the 3-4 clutches). This should give you some ideas on what to do.
Old Nov 21, 2003 | 04:31 PM
Marc 85Z28's Avatar
Pro Built is right. A couple years ago I had the same problem intermittantly. I put a Corvette servo in just because, not knowing it would help the problem. The problem went away for nearly a year. Then I bought a new trans
Old Nov 21, 2003 | 05:40 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Hmm....guess I'll throw a bunch of that stuff into a new tranny and then install it after mine craps out. Guess there is nothing I can do in the mean time. Doesn't really matter too much right now because tomorrow is the last time I can go to the track this year.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
