rear 10 bolt
Old Nov 23, 2003 | 06:51 PM
joshwilson3's Avatar
Old Nov 23, 2003 | 08:58 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check your RPO codes if you have them for G-80 which is for a limited slip rear (aka Posi). However with your combo I don't think you have it. Also the Diff fluid has nothing to do with your brake system.
Old Nov 23, 2003 | 09:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
how can I tell if it is a posi or not without having to remove the cover
By removing the cover. There's no other way to be sure. There's certainly nothing in the VIN code. If you're worried about the additive, get a bottle of it from Scoggin Dickey or something, and return or sell it if you don't need it. Odds are though, you won't have to worry about it; posi is extremely rare in the non-performance cars like TBI and 6-cyl ones.
Use the tubular style gasket. Screw a bunch of paper spacers.
The rear end grease and the brake fluid have nothing to do with each other.
Old Nov 23, 2003 | 11:24 PM
Old Nov 23, 2003 | 11:53 PM
Old Nov 24, 2003 | 07:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The "codes" only tell you what came in the car, not what's in there now. Many tales of woe have been posted about people who actually believed what their "codes" said, only to take their car apart and find something completely different from how the "codes" say it came (usually downgraded.... TPI motors with swirl-port heads, posi codes with one-wheel-peel in the car, etc.) Believe your "codes" if you want; but if you want to get it right with absolute certainty, take off your cover and look, otherwise you're taking a risk.
Don't bother with a paper gasket. It is a waste of time and money, and will be more likely to leak than the alternatives. Use the tubular style of gasket. I recommend Ultra Black.
Old Nov 24, 2003 | 07:40 AM
DJP87Z28's Avatar
Well Dude, I see you foung the codes. And DUDE, just keep what you have.
Old Nov 24, 2003 | 11:11 AM
Old Nov 24, 2003 | 11:16 AM
DJP87Z28's Avatar
Dude that Ultra Black comes in a squeeze tube, its not an regular gasket.
Old Nov 24, 2003 | 05:44 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Old Nov 24, 2003 | 06:48 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
LMAO, yeah we use red at work and it works just fine I couldn't tell you last time I have put a rear end gasket on. Actually I am on my way to my garage to put rear grease seals in and rear brakes.
Yes the rear end grease does run down to the axle tubes to the brakes, but there is a seal that stops the grease from entering the brake drum area. The brake fluid only goes into the wheel cylinders that push out the brake shoes. The two systems are completly independent of each other and if either one starts leaking into the brake drum area it will cause problems, hence why I am replacing both of them tonight.
Jason
Old Nov 25, 2003 | 12:49 AM
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
