T-5 shifter hurst,B&M etc..??
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
Im looking to buy a short through T-5 shifter for my 91Z
and Im wondering if anyone has bought one and what they think of any of them Hurst,B&M etc. thanks for any input
Car: 83Z28 HO
Transmission: G Force 5 speed
If $$$ isn't a big concern, the Pro 5.0 is a great shifter. I noticed an immediate improvement over the stock POS...it costs like 20-30 bucks more than the Hursrt though...
Car: 1991 Z-28
Engine: TPI
I have a Hurst, Billet Plus. Can't say how much it was, it was a Christams present. I have always heard good things about the Pro 5.0, but I do love that hurst. Entirely different feeling than the stock shifter, if you can call it that. imo, any aftermarket shifter is well worth it.
Car: 1991 Z-28
Engine: TPI
And the B&M these shifters dont come with the ****,you use your stock one..... $165+ for B&M and HURST, and $199+ for the Pro5.0
I dont like the looks of the B&M one it looks cheap...
but the other 2 look pretty tuff
so are they better as far as quicker shifts ? and I assume the shifter wont slam the plastic around the boot anymore?
yes, the shifter travel is greatly reduced, and there are adjustable stops to prevent you from going to far, which can bend the forks in the tranny. as for appearance, the hurst looks cool, but i don't understand why they anodize the base since you never see it.
Car: 1991 Z-28
Engine: TPI
was adjusting it pretty easy?? I know installing is easy,Ive done alot of T-5 swaps in my past Camaro
so have plenty of experiance with that part
Car: 83Z28 HO
Adjustment is a piece of cake....put in 1st and turn the screw in till it just touches the handle -, back out 1 turn and lock it in. Do the same in 2nd gear for the other stop.
The handle on my Pro-5.0 doesn't look like the one above, but it has the same base...
Nothing else to adjust. BTW....you won't need to adjust the B&M at all because - if the pic above is accurate - it doesn't have any stops!! That missing feature is a big turn-off IMO....
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I have the Hurst and I love it. It makes the stock shifter feel like a rubber stick...
These shifters lower the pivot point of the shifter arm, thus shortening the length of the throw.
Adjustment is easy, all you need is an allen and a wrench to tighten the set screw. As far as bending a fork, I wouldn't worry about because they generally break first since they're only made of aluminum.
On mine I drilled another hole below the ones that hurst drilled to mount it even lower (about 1"). That shortens the throws even more and it's an easy modification.
Car: 1991 Z-28
Engine: TPI
Car: '86 Iroc
Transmission: T-5 with Pro-5.0
Hi guys...
I am in the middle of a t5 swap right now and am looking for a shifter also. I may have found a B&M one and you are right, that is NOT the correct picture. At least the one I am looking at has a straight shaft and according to the guy that has it for sale, there are adjustable stops on it or else I wouldn't be interested in it either. That pic (above) is the one in Jeg's and Summit, but it must be for another application such as the t56...???
Car: 1991 Z-28
Engine: TPI
Originally posted by Vidman
Hi guys...
Hi guys...
Car: 1991 Z-28
Engine: TPI
I believe this is closer to the right pic but the base dont look long enough,but either way its similar and your right...the bent type shifter is for the t-5 in the 5.0 mustang.and it does have the stop adjustments but you cant see them because they are allen set screws to adjust them not visable bolts like the others
Car: 83Z28 HO
IMO the only choice is between Hurst or 5.0 - never been a fan of B&M anything, but that's just me.
Car: 1991 Z-28
Engine: TPI
Z dude - I'm not 100% positive whether the B&M shifter has stops or not. I am sure that I've read posts on this board where people said that the B&M shifter USED to come with stops, but the ones they sell now don't have them. Try a search.....or give them a call to verify.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
having used all 3 (pro-5.0, hurst, b&m)
i can tell you, the pro-5.0 is the one in my car
the hurst is also a very nice peice, but i love the 2-3 shift acuracy of the pro50
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
TAKE NOTE!
The B&M does NOT have adjustable shift stops!
Which among other poor features, makes it a pile of crap, and a bad choice. Don't make the mistake I did, of buying that shifter.
When I went to buy it, I called Summit, and asked them if it did have adjustable shift stops. They told me that it did. The thing came, no shift stops. Grrrrr.
I drilled and tapped holes where those flat pads youo see in the pics are, and made my own. But the thing is still a POS.
B&M USED to make a shifter WITH adjustable shift stops but when they came out w/the "Ripper II" THey did away with them. Bad idea.
Also, in my expirience, I have missed more shifts in one night at the strip w/ the B&M than I did in a season w/the STOCKER!
The B&M is no good. Please avoid it.
Car: 1991 Z-28
Engine: TPI
Re: TAKE NOTE!
paying the same as what they want for the Hurst and getting less of a shifter!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Go with the Pro 5.0. It is awesome. It is so much better than stock and makes a great metallic clink sound when you shift. Just look at the pics above and you tell me which one looks stronger. The Pro 5.0 has far more material than the others, especialy around the shifter handle. Also you can get it for 170 and not 200. You have to look around. I got mine for 175 on sale at thunder racing but an ad over on www.camaroz28.com has a special for 170. Here is a pic of it next to the stock one.
Car: '86 Iroc
OK...
You guys got me...
After reading all this, I ditched the idea for the B&M and just got off the phone and ordered a PRO 5.0!!!!! Ordered it from Year One for $185.00 plus shipping. (197.00) total. Jeg's was going to be$208.98 I believe. Anyway, I have no doubt the Hurst and B&M are good shifters, but people had their problems with one or the other whereas I read NOTHING bad on here about the pro 5.0. I am just a little excited, can you tell? *L* Later!!!!!!!!
You guys got me...
Car: 1991 Z-28
Engine: TPI
OK...
You guys got me...
OK...
You guys got me...
good site!
Car: 1990 Camaro RS
the one i have is actualy a GM performance parts one. they have been discontinued.
you can get basicly the same thing from MBA
Car: 1990 Camaro RS
Car: 1989 RS Camaro
Im puting a shifter in my T5 for christmas and im getting the hurst. For one because its a legendary name and has been around for 30 years, and two because imo i dont want to put a mustang shifter in my camaro, yes its still a great shifter but wouldnt be my preference
Engine: LT1, L400
I would think you would want the shifter that functions the best, regardless of name and heritage. But if it makes you happy, that's cool.
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Car: 1992 RS
Engine: 3.1L V6
I just installed a Hurst competition plus on my t5 and was REALLY happy with it. Then I saw this thing on ebay. It dropped my shifter down like 2 inches and shortened my shifts even more! It's the tightest, clickiest, shortest throw shifter I've ever felt. Sure there are ones shorter but you should seriously try it! My shift **** is almost in the boot!
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448339174
Car: 88 GTA
The Hurst shifter was the first mod I got for my car. I chose it because my dad got a Hurst for his 81 Corvette and it made a huge difference. Also the Hurst name is a plus. Honestly I didn't do much research on the topic, just bought.
The only gripe I had about it was in all the pictures you see in Summit and like the pic above, and on the box, the stick itself is short and curved, but the one that came with it was a tall straight peice. I didn't like the feel of that (I always rest my hand on the shifter, and my elbow didn't rest on the console..) so I went to a speed shop and ordered the shorter curved stick. It made the location of the shift **** lower and closer to the driver. I love it. That was another 30 bucks, plus I had to have the genuine Hurst shift ****, which was another 30 bucks.
Car: '90 RS
Engine: 377 LSX
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have the B&M... the only prob I have with it is that it rattles a lot, and seems to loosen up, no matter how tight I have it!!
3rd, 45051, billetplus, bm, camaro, catasauqua, gen, good, hurst, pa, performance, shifter, shop, speed, t5
