b&m/hurst torque arm bracket w/ a 4speed?
Old Dec 15, 2003 | 01:20 PM
jon_volk's Avatar
has anyone swapped a 4speed manual into their fbody and used the b&m or hurst torque arm bracket to attach the torque arm?
Old Dec 15, 2003 | 03:31 PM
ede's Avatar
ede
unless soemone found a 4 speed with the same bolt pattern as a th350 it wouldn't bolt up. chance it could be modified to fit or a bracket made to work. easier to get an aftermarket torque arm. you using a manual clutch with the 4 speed? how'd you work that out?
Old Dec 15, 2003 | 03:37 PM
jon_volk's Avatar
looking into a retrofit hydraulic throwout bearing to eliminate any mechanical linkage and use standard t5 pedal/master cyl setup. they have this type of t/o bearing available for any muncie, saginaw, t10...
just in the planning stages right now.
Old Dec 15, 2003 | 04:15 PM
jon_volk's Avatar
what does the b&m bracket actually bolt to?
Old Dec 15, 2003 | 04:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Trans mount
Old Dec 15, 2003 | 04:23 PM
jon_volk's Avatar
Originally posted by RB83L69
Trans mount
if i remember correctly from when i had my 68 camaro..the th350, powerglide, and 4 speeds all used teh same crossmember (i.e. same type of mount).... so in theory this should work? i think....
Old Dec 15, 2003 | 04:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe, assuming it clears the shifter, which goes at about the same spot.
You'd probably be better off just getting an aftermarket torque arm.
Old Dec 15, 2003 | 09:31 PM
jon_volk's Avatar
how was the torque arm attached to the saginaws available in early 3rd gens? did they have an fbody specific tailshaft? if the torque arm clears a saginaw linkage i guess it might work. needless to say i got a b&m bracket used for cheap so ill give it a try..if not ill just fab my own bracket
as much as id like an aftermarket torque arm..thats just not in the budget right now.
(yeah yeah, manual trannies and budgets arent exactly good friends )
86T/A_Ram_Air
Jun 21, 2014 05:34 PM
elano
Mar 12, 2009 01:23 PM
LottaBallsCamaro
Jun 12, 2002 10:14 AM
vortech305
Feb 26, 2001 06:10 PM
