kickdown cable for carbed & 700r4?
Old Dec 21, 2003 | 02:43 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
ive a bored 30 over 305 carbed engine with a 700r4, wish I had put the kickdown cable onto the trans before I lowered the whole thing in, to late tho-. The trans has a B&M shift kit in it but ITS a bear to try and hook the kickdown onto the little hook coming out of the trans, just slightly above the trans pan. Im at wits end and do Ineed the kick down cable and will it hurt without it? If its a matter of manual shifting I dont mind but dont wish to destroy a perfectly good 700r4.
Old Dec 21, 2003 | 02:49 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You must use the TV cable. Using the trans without one will result in shifts without proper presure to the clutches & bands when applied, and they will wear / burn prematurely.
Unhook the TV cable at the carb. Pull up gently on the J-hook until you can see it. Pull the cable out of the cable housing down at the trans., and slip it over the J-hook. Then put the housing back in and retain it w/ the bolt. I agree, the 700 can be tough to access on the right side, but ya gotta do it, and it's easier the 2nd time.
Old Dec 21, 2003 | 05:38 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
Yeah it's rather easy, simple hook it in and push it up in the hole and bolt the bracket up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
