700R4 Question
Old Dec 30, 2003 | 11:49 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
700R4 Question
I was just curious as to whether or not anyone has changed the servos and springs out in their 700R4 for a firmer shift at a higher rpm.
I would like to know what servos and springs everyone uses. Thanks.
Old Dec 31, 2003 | 02:22 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I'll be doing this soon in the 700R4 from my Blazer. I'm going with the JET servos. I researched all the options, and they have the largest apply area of any servo available.
Lots of guys also use the stock Corvette servo. It may still be available new from GM, but I can verify that.
Old Dec 31, 2003 | 04:35 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Isn't that called a shift kit?
Old Dec 31, 2003 | 07:17 PM
White91GTA's Avatar
Engine: 5.7L TPI
No, that is not a shift kit. It is actually better than using a shift kit and can be used in conjunction with a shift kit.
Old Dec 31, 2003 | 07:31 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Ahhh... well I am glad I opened my mouth.
Old Jan 1, 2004 | 12:44 AM
I would recommend using an upgraded servo with a shift kit. You won't get the full benefits of a shift kit with just the servo. The shift kit will also increase line pressure, and shorten the time required to complete the shifts.
Old Jan 1, 2004 | 01:15 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
I changed mine out with the much better Corvette servo and man it makes a big differance.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
