Best price and quality on 12-bolts
Car: 1983 Z28
Engine: 6.6L 406
Can you guys list where you got your 12-bolts, and what brands they are. and how much you paid. I am looking for a 12-bolt but want to make sure I get the RIGHT one. There are so many manufactureres out there right now. thanks
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Best price and quality on 12-bolts
I plan to find a used 10 bolt posi and swap the 3.73 ring and pinion I have in my one legger now, and hope it holds. I just won't have the $$$ for a 12 bolt for awhile....
A Ford 9" is an option too.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Actually, that is not a horrible price for the rear end. I just checked the local speed shop, and they wanted $2,055 for the Moser 12 bolt rear before the options.
They also told me something I did not know. 12 bolts are more efficient than the 9", thus making more rear wheel hp. Something about the way the gears align.
Car: 1992 B4C 1LE
it has to do with the relation of the pinion to the ring gear. A 9 inch is very inefficient, I can tell you from experience they are very heavy too unless you get an aluminium housing.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, but all the stuff about weight and pinion placement doesn't mean jack in the real world. I read an article not too long ago where they ran a 9", a 12-bolt, and a Dana 60 in the exact same car, with the same gearing and style centersection in all the rears. There was no noticeable difference in strip times. A hundreth of a second or so, but if you looked at all the runs the difference between runs with the same rear were often speratated by a hundreth or two, meaning that the rears had basically no effect on performance.
In theory a 12-bolt has the least amount of friction because of the pinion placement. A Dana 60 is definately heavier than either a 9" or a 12-bolt (they don't call it a flying anvil for nothing).
The cheapest I've seen bolt-in 12-bolts for 3rd gens is about $1,650 directly from Moser. 9" Fords seem to actually be a little bit more expensive.
Engine: LO3;383tpi
you need to consider shipping cost. also it's usually cheaper to buy the parts and do the assembly yourself.
Linson
Sep 21, 2015 01:08 PM
rb85TA
26
Sep 14, 2015 10:29 PM
