will a 89 700r4 work in a 91 z28?
Old Jan 11, 2004 | 05:55 PM
mckenzie's Avatar
hello, will a 1989 700r4 work in a 91 z28? i think the 89 has a cable speedometer, and the 91 has an electric speedometer. will i have to swap rear tailshafts? anybody know what all is involved? thanks, tom
Old Jan 12, 2004 | 12:09 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If the trans is from an '89 Camaro then it is a mechanical drive. If it's from a Firebird it's electric. Your '91 is electric. Just swap the tailshaft housing and the speedo gear on the tailshaft of you trans onto the new one and you're good to go.
Old Jan 12, 2004 | 12:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: will a 89 700r4 work in a 91 z28?
If it's different tooth count, you need the drive on the output shaft of your 91 trans. Your VSS assy. will swap directly into the 89 tailhousing. The tailhousings will be identical if they are both from f-bodies.
700-R4 truck tailhousings are bare. B/D have a mount provision on the underside. Y are weird (as are some owners of same.) F are setup for a tq. arm.
Everything else should be cool as long as they're both Chevrolet pattern (and not from a V6 for example.)
1992rs/ss
Jan 31, 2025 05:10 PM
jklein337
Sep 19, 2018 06:23 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Aug 6, 2015 04:15 AM
