700r4 problem 1st only
Old Jan 17, 2004 | 04:42 PM
jobberroll215's Avatar
Car: 87 z28
Engine: 5.0
Transmission: t5
I any one can help it would be greatly apreciated, my friends tran will not shift out of first gear this happened with out warning trans fuild is still red and has no bruned smell can any one out there give an answer to this problem
Old Jan 17, 2004 | 06:14 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Stuck governor is a definite possibility.
Old Jan 18, 2004 | 12:11 AM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
Mine too. How do you unstick it? Take it all apart and clean? Is the governor inside the valve body? ThanKs, Tim
Old Jan 18, 2004 | 01:44 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
i'd say a stripped governor gear. i think they're about 20 bucks from gm and not hard at all to replace.
Old Jan 18, 2004 | 09:56 PM
The governor is under the governor cover (rounded metal cover on the left side of the trans). It isn't in the valvebody, so you don't have to drop the pan. It's fairly easy to get to.
camaro11j
Sep 19, 2018 08:49 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
someone972
Aug 30, 2015 12:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
