welding the spider gears?
Old Feb 1, 2004 | 12:59 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
a freind told me that if i weld my spider gears together or sumthing along the lines of that. it will make my 96 rearend similar to a locker. is this correct?
Old Feb 1, 2004 | 01:31 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
Um no....it will be locked, like a non differential. Known as the poor mans spool
Old Feb 1, 2004 | 02:07 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yea, just don't do any turning =/.
Old Feb 1, 2004 | 03:46 AM
Pro Built Automatics's Avatar
Dangerous in the rain, and hard to turn.
Old Feb 1, 2004 | 07:37 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Dangerous in the rain?, my car has posi and its dangerous in the rain.
Old Feb 2, 2004 | 01:04 PM
EvilCartman's Avatar
Car: '82 Z28
I have a locker and it's fine in the rain Whole lot better than when it was an open rear.
Old Feb 2, 2004 | 01:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you guys left out the real danger.
the GM axles are held in by a lil clip inside the diff.
that tiny C clip is the ONLY thing holding your axles in.
the stock axles arnt very strong.
if you weld the gears together and drive on the street, the stress of the the two wheels trying to turn diffrent speeds (and ending up slipping the tires instead)is huge.
eventually the axle fails. itbreaks. now on a ford or any other non Cclip car, its not a big deal.. pull over to the side of the road and get a tow.
but since thoes tiny c clips are in the middle of the axle.... when it breaks, the axle starts to slide out. and you get somthing like this:
dangerous and stupid thing to do.
Old Feb 2, 2004 | 02:13 PM
pasky's Avatar
I guess doing that would be ok for a car that just goes straight (one strickly for track), but i'd rather spend the money to buy a new rear or posi unit. Get the slp take off unit, its 99 bucks and very good from what I hear, im installing one as we speak, soon as I get home from work.
Old Feb 2, 2004 | 03:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I doubt you're going to find too many tracks that will let you run if they find out you have welded spider gears.
Old Feb 2, 2004 | 03:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
guy came into the high school autoshop back when i was in high school... had a V8 in a S10....
i watched him weld up the gears...
2 months later, it broke, and he smashed into a jersy barrier... totaled the truck.
it is NOT a good idea.
Old Feb 2, 2004 | 04:38 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Most people refer to limited slip as Posi. Limited slip, or a locker, lets you turn corners, which this isnt about. This is LOCKED, just like a spool. The wheels MUST turn the same speed and direction at all times.
Looking at my 2 sec drawing(representing tires on a turn) you can see why you cant run a welded or spooled rearend on the street very long without problems. The outside tire must rotate faster and has farther to go around a turn, while the inside tire rotates slower and has less distance to travel. This will cause bindage in a locked rearend.
Posi/LSD/Lockers/spools/welded are all a little tricky in the rain, both tires will loose grip if too much throttle is applied, makint it easier for the car to spin...
Old Feb 2, 2004 | 04:58 PM
Engine: peanut LB9
hey MRDUDE, do u remeber where u got that pic from and whos car it was of,
if ya don't it was mine lol
neway i don't plan on doing this but me a few friends had a large argument over this topic because one of them was saying that if u weld them it will become a one legger.
i just wanted to ask about it
Old Feb 2, 2004 | 05:03 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
those look like 225 or 235 tires in that pic???
Old Feb 2, 2004 | 05:35 PM
Engine: peanut LB9
245/60r15's
Old Feb 2, 2004 | 06:25 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
woah, i didnt know about that c clip thing.
thanks MrDude-1 you taught me something new. (not that i was thinking of welding my axle or anything...)
Old Feb 2, 2004 | 06:27 PM
Engine: peanut LB9
my axles wheren't welded.
my c clip just got a lil misplaced
Old Feb 2, 2004 | 07:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yea, but it has the same effect.
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
fasteddi
Sep 10, 2015 09:32 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
