Car will not shift right!
Old Feb 5, 2004 | 06:42 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I have a 1984 700R4 transmission. I had a shop do a distributor & carb swap (Demon 650) about 3 days ago since then my car has not been shifting correctly it will not up shift till 3000rpm at part throttle and the passing gear will not engage at all. I brought it back to the shop and they tried adjusting the TV cable and still no change. I have been reading and it says that if a transmission does not receive enough vacuum it could cause late shifts, can it be a vacuum hose not hooked up correctly? Any advice is helpful.
Old Feb 5, 2004 | 07:09 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
No vacuum on a 700r4. TH350 yes, 700 r4 no. I would still think TV Cable adjustment.
Old Feb 5, 2004 | 07:49 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Well he reused the q-jet throttle and TV cable brackets and just used the holes that were already on the Demon's linkage. Do I need to get an aftermarket-mounting bracket? I had bought a Spectra TC and Throttle bracket but he said it did not fit and sat to low?
Old Feb 6, 2004 | 10:23 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
TTT anyone?
Old Feb 6, 2004 | 12:41 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I would bet where the tv cable is placked on the linkage is either pulling it too tight( too soon). You need to back off the adjuster and slowly work your way up on the tension.
Initally it will shift too soon. then as you adjust it will get closer to where you like it. Beight that it is not stock it will take some fooling with to get it set.
Old Feb 6, 2004 | 06:32 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I had to take it to a trasmission shop to have it adjusted right he finally admited he really didn't know how to adjust it. they had to move the braket back some and then adjust the cable it shifts great!!! 1500 1-2-3-4 and wot is about 4500 in OD thanks for all the help!
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
