T-56
Old Feb 6, 2004 | 08:18 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
T-56
Can some one tell me if there are any distinctive marks to identify a T-56 tranny. I found a roadside mom and pop shop who buys the contents of delinquent storage units from auction.. afterwards they try and sell the stuff. I drove by a found a crate, full of tranny dis-assembled(bellhousings, flywheels etc.). It's definately a stick... but how can I tell if it's a t-56??
Old Feb 6, 2004 | 08:42 AM
CScheip92's Avatar
Car: 1992 Camaro RS
Engine: LO3
Look at the following picture:
http://images.cardomain.com/member_i...090_1_full.jpg
I think they should all have that sticker and tube, electrical connections, etc. Search around my site there are a few more pics. I'd compare them and if there is a shifter on it, try going through all 6. Reverse is also all the way right and up.
The problem is there are 3 different T56's- Mustang, F-body, Viper. I don't know how to tell them apart. Oh and there is also a sticker on mine that says "USE ATF Dextron II Only", it's on the bottom, near the drain plug.
Old Feb 6, 2004 | 12:46 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
See if it has 6 gears for one. Only a handful of transmissions do.
It should have one square cover with 4-bolts between the bellhousing flange and the shifter.
The trans case is a three part affair with a back plate, a center housing, and the tailshaft.
Look for torque arm mounting holes too.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
'91 Formula
Nov 25, 2001 04:58 PM
