Help!!! Shifter boot
Car: 88 GTA, 89 GTA, 89 Bird
Engine: 5.0, 5.7, 2.8
Transmission: Manual, Auto, Auto
I may sound like an idiot. but i want to swap my boot and shifter **** on my 88 GTA 5 speed. For the life of me i can not figure out how to get it off. Please help me.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Hahaha, you poor guy, just twist your shifter **** off, then take off the shifter plate torx screws. If you mean the lower boot, well some of those bolts are hiddent under the carpet sometimes, easier to remove the console to get to them.
i am not sure thats how it works. i have had three people including myself try to twist it and it will not budge.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
maybe it striped out a long time ago and somone use liquid nails on it. i did this once when my jeep got stripped, figured once it hardened it would just form new threads on the ****, tryed t take it off a week later with a pipewrench. stuck like a .... just real stuck, man that stuff kicks ***.
handle
rb83l69; if you ever find out how the handle comes off please post it i have the same problem i tried a pipe wrench and it just tore up the handle i think it is pressed on cause i don't see any threads on the handle shaft.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: handle
Axle/Gears: 9-bolt/3.45
They're secured with a lock-tight-like product. So just keep trying, counter-clockwise, and you'll break it lose. No worries, nothing else will break.
handle
i'am trying to get the handle off at the bottom where it connects to the shaft that fits in the base plate that bolts to the tranny all it does is twist a little bit and comes right back to the same place i hope some one knows how it comes off.
Car: 1990 Formula
Transmission: WC T5
Re: handle
Car: '90 RS
Engine: 377 LSX
Re: Re: handle
Originally posted by novass
It does not come off there!! It is permanately attached with an elastomeric compound. Some of the early 80's you could separate, mid 80's on are permanently attached there!
happy to say that **** and boot are off with the help of a pipewrench. thank you. my B&M t shifter is on its way
Car: '90 RS
Engine: 377 LSX
Here is a little side by side comparison pic. You can see how an aftermarket shifter like my Pro 5.0 has a removable handle. You can see how the stock shifter is one piece. You can also see what it looks like with the **** off.
