Ls1 Vs Lt1 Drive Shaft
Old Feb 8, 2004 | 08:37 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I am about to purchase a new aluminum driveshaft for my sickly bird. I have the choice between an LS1 shaft and an LT1 shaft. They both sell for around $220. So what do you think.
Old Feb 8, 2004 | 09:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Get an LS1 driveshaft. You can find them on ebay and the boards for really cheap (100-200). They aren't steel like the LT1's and are extremely light and can withstand serious power levels before they fail. They are also balanced very well. The LS1 shaft is one GM part that is almost better than the aftermarket stuff. There isn't anything special about an LT1 shaft and I cannot wait to get rid of mine and go with an LS1 shaft in my 95.
Old Feb 8, 2004 | 11:07 PM
MdFormula350's Avatar
LS1 aluminum i would go with.
Old Feb 9, 2004 | 12:15 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
LS1 hands down, its bigger in diameter, lighter and has a harmonic dampener.
Old Feb 9, 2004 | 12:01 PM
joshwilson3's Avatar
Old Feb 9, 2004 | 12:27 PM
pasky's Avatar
Definatley grab it if its below 150 for it, if not, go to www.car-parts.com, I picked mine up from one of the yards on there for only 110.
Old Feb 9, 2004 | 12:41 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by joshwilson3
Is LS1 cars the only ones that came with aluminum driveshafts? That would be 98+ cars right? I think there is a wreched 4th gen bird at the local junker with what appears to be an aluminum driveshaft in the car. It didn't look rusty and was fairly light. Should I grab it?
That is right unless any year 3rd, or 4th gen was equiped with a 1LE shaft. The LS1 shafts are actually lighter. They are really that good.
Old Feb 10, 2004 | 01:48 AM
Old Feb 10, 2004 | 07:23 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I have a stock 1989 305 V8 TBI with 2.73 open. I was thinking of getting the SLP posi with 3.73 gears. How much will the aluminum shaft help?
And I guess I can just take a magnet with me and see if it sticks? That would probably be the easiest to tell, right?
That would work and the LS1 shafts are 3" diameter (larger than yours) and have a greyish hue to them. If it is out of an LS1 car you are garanteed it is an LS1 shaft. The only exception are a few 2.73 rear auto cars that got a steel shaft. But if it is out of a T-56 car you are set. The driveshaft would be a good idea with 3.73 gears because your shaft is going to be spinning at a lot higher rate than it did before with the old gears. Therefore vibrations you felt at high speeds will now be felt at lower speeds.
1984HO
Mar 19, 2021 11:59 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
