How much gear lube in the differential?
Old Feb 14, 2004 | 08:02 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I put about 2 quarts in with a packet of posi additive, is this adequate?
Old Feb 14, 2004 | 08:10 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Should be good. You fill until the oil is just at the plug a little below is fine.
Old Feb 14, 2004 | 08:13 PM
pasky's Avatar
I couldn't see the oil, thats my prob, however it was coming back out a little, but I think it was being syphoned. Just want to make sure if 2 quarts will be okay.
Old Feb 14, 2004 | 08:22 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Rotate the axle a few times then stick your finger in the hole and if you can feel oil your good to go.
Old Feb 15, 2004 | 09:12 AM
ede's Avatar
ede
i usually fill it till it starts to run out the fill hole then put the plug in it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Sep 19, 2015 08:13 PM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
