Has any one been able to find a source for new clutch pedal pads?
Old Feb 16, 2004 | 08:16 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have not been able to locate a replacement, stock hex pattern, clutch pedal replacement pad. Year One and Classic Industries carry only the break pad not the clutch pad.
Any Ideas?
Old Feb 16, 2004 | 08:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if im not mistaken, (and i might be), i think the clutch pad and the brake pad are the same pad on 3rdgens.
they're only diffrent on 4thgens because the law says they have to have "ABS" cast into them.
Old Feb 16, 2004 | 10:27 AM
smithtc's Avatar
I'm in the same situation.
Brake pad is not the same.
I'm currently looking into wether a 4th gen clutch pad will fit. Seems like I've seen those on some cars, and they were hex shaped.
Old Oct 4, 2004 | 10:37 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i got one, i got a clutch and brake pedal pad from like autozone or pepboys (dont remeber) so they are out there! sorry if this is dead, searching
Old Oct 4, 2004 | 10:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had my GM parts man do a search for me. I had them within a couple of days.
JamesC
Old Oct 4, 2004 | 11:34 AM
smithtc's Avatar
Hex shaped?
Old Oct 4, 2004 | 11:46 AM
JamesC's Avatar
Yep. Because an item has been discontinued by GM doesn't mean that a dealership(s) somewhere doesn't have that item in stock. I've gotten pieces such as L69 exhaust parts, IROC door decals, pedals, and so on using this method.
JamesC
Old Oct 4, 2004 | 06:09 PM
smithtc's Avatar
I tried this method with no success.
Maybe you could score a few and send us some for a small profit.
Old Oct 4, 2004 | 06:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
autozone and those store have them. you need to check them all though. my local one only has the standard style but, the one in beloit had the hex pattern
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
