th-350 swap
Old Feb 17, 2004 | 05:49 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
th-350 swap
i have searched forever and still do not have a solid answer. i have a th350 with a 6inch regular tailshaft. i have a 700r4 xmember and 700r4 drive shaft. what parts do i need to bolt this th-350 in my car? i have read a hundred different post and wouild just like a definate answer. thanks
Old Feb 17, 2004 | 06:07 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you either need your driveshaft lengthened or a driveshaft from an 82 f-body with a 200C tranny
you also need the B&M torque arm mount kit
end of story
(although there are other, more expensive options other than the B&M kit)
Old Feb 17, 2004 | 07:06 PM
bubbz89's Avatar
Car: 1990 RS
so my xmember will work
Old Feb 18, 2004 | 05:55 AM
ede's Avatar
ede
yep, the drive shaft is the only "problem" area and it's not much of a problem
Old Feb 18, 2004 | 06:30 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
my camaro was the unlucky 200c model and i had to oblong the X members hole very slightly in order to accept the th350 but otherwise yeah it fits right up
Old Feb 18, 2004 | 06:34 PM
bubbz89's Avatar
Car: 1990 RS
thanks guys!!!!!!!!!!
Old Feb 25, 2004 | 11:10 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Old Feb 26, 2004 | 12:39 AM
mike's91RS's Avatar
Car: 88 Monte Carlo LS
Transmission: 200R4
what about the speedometer?
I am doing the same swap on my 91 but don't know about the speedometer
Old Mar 5, 2004 | 08:28 PM
bubbz89's Avatar
Car: 1990 RS
not sure on the speedo, this is mainly a track car, so i am not using one.
Old Mar 5, 2004 | 11:43 PM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
I used the B&M Kit, custom driveshaft from local machine shop.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
