ANOTHER problem with 700R4 now!
Old Feb 20, 2004 | 09:51 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Now that ive fixed the reverse problem (retainer ring on roller clutch installed incorrectly) I have 2 issues to deal with still..
Issue#1 is That I have no engine breaking in Manual 1st gear, it just neutrals itself when i let off the gas.
Issue#2 is that I have very late hard shifts, even under light throttle i get a 4000 rpm shift. adjusting the TV cable or even unhooking it makes no difference. Im assuming this means there is a problem in the TV circuit.. But I checked and doubled check, the valve bounces freely and does not stick.
But still the two obvious things here are Governor, and TV valve. can anyone think of anything else?
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
